SD interface object - file size?
Please help: I am using an 1G SD memory card
The buffer block in SD interface object has a limit 512 bytes, what is the best approach to write more data to a file (>512 bytes)
The file itself can be as large as the medium (1GB in this case). The buffer is 512 bytes because that is what Windows (or DOS or Linux) expects for a block size. If you don't need DOS / Windows compatibility, you can write smaller or larger blocks to the SD card.
Post Edited (Mike Green) : 3/21/2008 3:32:00 AM GMT
