need help understanding some Assembly code
The codes below are from an example found in this forum used for reading DS1302 timekeeping chip and displaying the values on an LCD .
I was analysing the ASM equiv of the SX/B code block below in order to fully understand the SHIFTOUT implementation in ASM coding.
FROM the· assembled output lst file
·179· =000000BF······ BurstRead···· EQU· $BF···
·508· 015E· 0CBF······· MOV __PARAM1,#(BurstRead & 255)
······· 015F· 0028
·· 509· 0160· 0C00······· MOV __PARAM2,#(BurstRead >> 8)
······· 0161· 0029
What is the end value stored in __PARAM1 as well as __PARAM2 , and why the assembler used this technique instead of directly using the valye of the constant ?
What is the purpose of using __PARAM2 variable in the loop knowing that it is only referenced at line 517
with one command RR __PARAM2· only ?
--- Source SX/B· code
GetTimeAndDate:
·HIGH RTCCS····' start transaction
·SHIFTOUT Dta, Clk, LSBFIRST, BurstRead·' write address
·FOR Idx = Secs TO Ctrl···' read time registers
·SHIFTIN Dta, Clk, LSBPRE, TimeDate(Idx)
·NEXT
·LOW RTCCS
RETURN
End SX/B Code
Complete Block···
·· 491· =0000014B······ GetTimeAndDate:················· ;GetTimeAndDate:
·· 492·················
·· 493· 014B· 0545······· SETB RTCCS···················· ;····· HIGH RTCCS····························· ' start transaction
·· 494· 014C· 0CFA······· MOV FSR,#__TRISA·············
······· 014D· 0024
·· 495· 014E· 0440······· CLRB IND.2···················
·· 496· 014F· 005F······· MODE $0F·····················
·· 497· 0150· 0200······· MOV !RA,IND··················
······· 0151· 0005
·· 498· 0152· 0018······· BANK $00·····················
·· 499· 0153· 0545······· SETB RTCCS···················
·· 500·················
·· 501· 0154· 0C08······· MOV __PARAM3,#8············· ; SHIFTOUT Dta, Clk, LSBFIRST, BurstRead· ' writeadress
······· 0155· 002A
·· 502· 0156· 0CFA······· MOV FSR,#__TRISA·············
······· 0157· 0024
·· 503· 0158· 005F······· MODE $0F·····················
·· 504· 0159· 0420······· CLRB IND.1···················
·· 505· 015A· 0400······· CLRB IND.0···················
·· 506· 015B· 0200······· MOV !RA,IND··················
······· 015C· 0005
·· 507· 015D· 0018······· BANK $00·····················
·· 508· 015E· 0CBF······· MOV __PARAM1,#(BurstRead & 255)
······· 015F· 0028
······· 0161· 0029
·· 510· 0162· 0708······· MOVB Dta,__PARAM1.0··········
······· 0163· 0425 0608 0525
·· 511· 0166· 0C05······· MOV __PARAM4,#5··············
······· 0167· 002B
·· 512· 0168· 02EB······· DJNZ __PARAM4,@$·············
······· 0169· 0010 0B68
·· 513· 016B· 0C01······· XOR RA,#%00000001············
······· 016C· 01A5
·· 514· 016D· 0C05······· MOV __PARAM4,#5··············
······· 016E· 002B
·· 515· 016F· 02EB······· DJNZ __PARAM4,@$·············
······· 0170· 0010 0B6F
·· 516· 0172· 0C01······· XOR RA,#%00000001············
······· 0173· 01A5
·· 517· 0174· 0329······· RR __PARAM2··················
·· 518· 0175· 0328······· RR __PARAM1··················
·· 519· 0176· 02EA······· DJNZ __PARAM3,@$-20··········
······· 0177· 0010 0B62
Regards
······· 015F· 0028
······· 0161· 0029
GetTimeAndDate:
·NEXT
·LOW RTCCS
RETURN
End SX/B Code
Complete Block···
······· 014D· 0024
······· 0151· 0005
······· 0155· 002A
······· 0157· 0024
······· 015C· 0005
······· 015F· 0028
······· 0161· 0029
······· 0167· 002B
······· 016C· 01A5
······· 016E· 002B
······· 0173· 01A5
Regards
You can actually shiftout WORD variables. SX/B uses the same code whether the variable is a word or a byte.
If you are converting to ASM you can just load __PARAM1 with the byte value and forget about __PARAM2.
Bean.
www.iElectronicDesigns.com
