Tips on using LCD Appmod
I am getting the LCD Appmod tomorrow. I have heard it is rather difficult to program. Any tips on your problems or just help on how to use it would be appreciated. Thanks!
Dan Taylor
Dan Taylor
Its not so much that its harder to program, just that its more involved than using a serial LCD.
The Appmod is sent data in 4-bit parallel nibbles. Also, it has to be able to read the 4 push-buttons.
I'd recommend wiring it up according to the sample circuit which comes with it and run the sample program until you get comfortable with it. Once you are on to it, you'll be fine.
Cheers,
Tom Sisk
http://www.siskconsult.com
Dan Taylor
Try to be more descriptive…What do you mean you can’t make it do anything? You said the test program worked…Have you looked it over to see how it displays information?
Dan Taylor
Dan Taylor
