Blue Tooth Connection Help
Hi, I have just installed the eb500 module on my BOE. I can not pair the module
with my PC. I am running Vista and·I get a message asking for a·security code.
I tried·a dummy code, no code·with no luck.·Am I missing something?
My PC does discover the module - I·can not pair with it.
When following the MSRS-Bluetooth-Boe_Bot_v1.5.pdf I get to the point where I am running the program and i get the following message.
**Initializaion failed in DSS boot loader: Could not start HTTP Listener.
The two most common causes for this are:
1) you already have another program listening on the specified port
2)you dont have permission to listen to http requests. Use the httpreserve command line utility to run using a non-administrator account.
exception message: Access is denied
Does anyone know what this means/ what im doing wrong?
Vista blocks a lot of interaction to hardware by most programs
unless you are logged on as an administrator.
Also the PDF for the EB500 is very confusing, here is a document I
prepared that might help you further.
