Passing variables
How would I pass a variable in one object to another? It seems my way isnt working how I want?
Hunger hurts, starvation works!
''Hyperterm throttle
CON
_CLKMODE = xtal1 + pll16x
_xinfreq = 5_000_000
pin = 4
VAR
long stack[noparse][[/noparse]30]
byte cog
OBJ
input : "FullDuplexSerialPlus"
esc : "ElectriflyESC"
PUB main : okay | pulse
input.start(31, 30, 0, 9600)
waitcnt(1_000_000 * 100 + cnt)
repeat
stop
input.Str(String("Enter speed: "))
pulse := input.getDec
okay := (cog := cognew(esc.Throttle(pulse), @stack) + 1)
repeat 2
input.str(String(10, 13))
PUB stop
if cog
cogstop(cog~ -1)
{{ElectriflyESC.spin
This object is for Electrifly SS-35 to initialize and control throttle settings for aircraft.
FullBrake = 100 or 1ms
FullThrottle = 220 or 2.2ms
Calibrating the ESC: apply full brake and pause for 1/2 a second, apply full throttle
and pause for another 1/2 second, and lastly bringing it back to full brake and pause for 1/2 a
second.
CON
pin = 4
OBJ
debug : "FullDuplexSerial"
VAR
long tC, tHa, t
PUB initialize
fullBrake 'Fullbrake
Delay(500) 'Delay 500 mS
fullThrottle 'Fullthrottle
Delay(500)
PRI fullBrake
ctra[noparse][[/noparse]30..26] := %00100 'Configure counter A to NCO mode
ctra[noparse][[/noparse]8..0] := pin
frqa := 1
dira[noparse][[/noparse]4]~~
tC := ((clkfreq/ 100_000) * 2000) ' Set up cycle and high times 20ms
tHa := ((clkfreq/ 100_000) * 100) ' 1.0ms pulse
t := cnt 'Mark counter time
repeat 150
phsa := -tHa ' Set up the pulse
t += tC ' Calculate next cycle repeat
waitcnt(t)
PRI fullThrottle
frqa := 1
tHa := ((clkfreq/ 100_000) * 220) ' 2.2ms pulse
repeat 150
waitcnt(t)
PUB throttle(pulseWidth)
debug.start(31, 30, 0, 9600)
debug.Str(String(10, 10, 13, "You Entered", 10, 13, "--------------"))
debug.Str(String(10, 13, "Speed: "))
debug.Dec(pulseWidth)
'ctra[noparse][[/noparse]30..26] := %00100 'Configure counter A to NCO mode
'ctra[noparse][[/noparse]8..0] := pin
'frqa := 1
'dira[noparse][[/noparse]pin]~~
'tC := ((clkfreq/ 100_000) * 2000)
'tHa := ((clkfreq/ 100_000) * pulseWidth)
't := cnt
'repeat
' phsa := -tHa
't += tC
'waitcnt (t)
PUB Delay(mS)
waitcnt((clkfreq / 1000 * mS) + cnt)
I recall it's not possible to start a method in a different object that way. The method has to be within the object from which it is started.
