Programing this LCD HD44780
Im trying to learn how to program this certon LCD...
I was wondering if someone can give me a simple program I can edit to learn from...
Just a simple text program so I can understand LCDs
LCD:
http://www.shopeio.com/inventory/details.asp?id=931&cat=Lcds&sub=Character%20Lcd
LCD spec:
http://www.shopeio.com/inventory/pdf/AMC1602A.pdf
Thanks, Ivan
LCD:
LCD spec:
Thanks, Ivan
Have a look at LCD Driver HD44780 16x2 4 bit 8 bit DEMO in the Propeller Object Exchange.
Yah but when I run it... it cant finde the "timing" file...
how do I make or finde that file...
Do I have to add the timeing of my serton LCD?
Thanks, Ivan
Post Edited (Save Mart) : 3/19/2008 4:17:02 AM GMT
oops ! somebody posted even more concrete than me while i was in edit-mode
anyway:
the manual that you quoted above contains some information about the interface (the PINs and their function) and the bitbanging.
here is a website with information about interfacing an HD44780-controller
http://www.myke.com/lcd.htm
if you are common to c/c++ you can google for HD44780-sourcecode for Atmel AVR-MCUs, or ARM-MCUs etc.
using the google-parallax-search engine
gives hits about the keyword 44780
http://search.parallax.com/search?ie=&q=+"f=25"+44780&site=parallax&output=xml_no_dtd&client=parallax&btnG=Google+Search&access=p&sort=&lr=&num=100&ip=88.202.126.34&proxystylesheet=parallax&oe=&filter=p
best regards
Stefan
in the manual on page 134 there is an example how to make a cog wait for milliseconds
it is the file (Ch3-Ex10)-Output.spin which is installed by the propellertool
under examples\manual
best regards
Stefan
