Exp board, wont run w/o usb?
So If I dont have my usb plugged into the board, it turns on for about a second and then resets?
Any Ideas why?
Works find once its got the usb cable plugged into it. after a power reset.
Any Ideas why?
Intermittently, you can get spurteous resets with power coming from the transmit (to the PC) line on the Propeller. The solution is to disconnect it or to add additional loading to the DTR and receive (from the PC) line. Something as simple as a 1K resistor to ground will help.
But its dead now... So I guess it was just on its way out.
Thanks anyway.
