TEST and INA ? — Parallax Forums
TEST and INA ?
jazzedjazzed Posts: 11,803
edited 2008-03-18 18:25 in Propeller 1
Maybe I haven't had enough coffee, but .... does INA work with the TEST instruction?
'This works
                mov     rxbit,          ina
                test    rxbit,          #2 wz ' test value & convert to bool
                if_z    mov     rxbit,  #0
                if_nz   mov     rxbit,  #1
'This doesn't ????
                test    ina,            #2 wz ' test value & convert to bool
                if_z    mov     rxbit,  #0
                if_nz   mov     rxbit,  #1
TIA
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
  • nutsonnutson Posts: 242
    edited 2008-03-18 15:27
    Look in the "tips and traps" sticky page 6. INA cannot be used as·the destination register
    edited 2008-03-18 15:43
    jazzed,
    nutson·is correct.· Look at Chapter 1 for the Propeller (1:Introducing the Propeller Chip) on the first page (page 23 of the propeller manual hard copy)
    There, you will find a table of registers that states that the INA, because it is a read-only register is·"...Only accessible as a Source Register (i.e. MOV DEST,SOURCE)."
    Since you can't have a constant in the DEST field either, you can pre-define a variable value to use in the DEST, so your code might look something like this.
                    test    temp_var,      ina wz ' test value & convert to bool
                    if_z    mov     rxbit,  #0
                    if_nz   mov     rxbit,  #1
    rxbit         long      0
    temp_var      long      2
    Beau Schwabe
    IC Layout Engineer
  • jazzedjazzed Posts: 11,803
    edited 2008-03-18 16:05
    Great [noparse]:)[/noparse] Thanks for suggesting the cycle saving alternative Beau.
    edited 2008-03-18 18:14
    jazzed,
    To save cycles, you should also look at the MUXNZ operator...
                    muxnz   rxbit,  #1
    rxbit         long      0
    temp_var      long      2
    Beau Schwabe
    IC Layout Engineer
    Cool 8-) I almost made that connection. Thanks for the push [noparse]:)[/noparse]
