tvIRC client for propeller
Oldbitcollector (Jeff)
I'm been driving the regulars crazy at #propeller for the last couple days
(sorry guys! it was for a good cause!) with the testing of the following IRC client...
TV IRC CLIENT
This is an AI_Generic version of Harrison's VGA client with a some mods/hacks,
a little color, and a lot of crunching to get it to fit into the AIGENERIC text client.
I believe I have most of the bugs beat down on this.
Operational notes:
Change the IP address, etc to match your PropNIC(or compatible) network settings.
The client will allow you to type up to 80 visible characters at a time in the bottom
two lines of the screen. (More are possible, but invisible, due to screen size constraints.)
At 22 lines, the display portion of the screen, clears, and moves back to the top of the
window. (Sorry, AIGENERIC isn't a windowed client, *yet*) This was a good way to
deal with this.
Enjoy! Thanks Harrison for a great base!
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Post Edited (Oldbitcollector) : 3/19/2008 1:35:42 AM GMT
TV IRC CLIENT
Operational notes:
deal with this.
OBC
Now all the PropNIC owners should be able to get online really easily. And from their living rooms!
See you there.
Cheers,
--fletch
Join us in the Un-Official Propeller IRC channel: irc.freenode.net #propeller
Newbies, oldies, programmers, math professors, and everyone in-between welcome!
Propeller IRC howto
spinc - open source Spin compiler
New update is now attached to top thread.
OBC
We need to get more projects rolling over IRC. Such a great way to collaborate!
A while back, stevenmess2004 (I believe) had the idea of a collaborative IDE that runs on the prop. Such cool stuff!
Cheers,
--fletch
Propeller IRC howto
Have stopped work on mine as yours is clearly better than a noob like me could do.
Does this mean that you are planning on making it windowed or are you hoping someone else will?
Keep up the good work.
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Post Edited (computer guy) : 3/20/2008 7:20:58 AM GMT
Unfortunately, compared to many here, I'm still in noob status
as well, so it may be a bit until I get enough .spin down to improve that....
OBC
Then is will truly be the best way to show text on a tv.
Building Blocks To The Propeller Chip
I am able to receive messages fine, however if I try to send a message it never gets through.
Is this because I am using a 6mhz crystal?
The enc28j60 driver says
Thank you
Thank you anyway steven.
Anyone have any idea as to why this is happening?
Thank you
I can receive messages fine, it is only outgoing.
Thank you
This leads me to believe that it is a syntax error causing the problems.
OBC, have you got more recent code?
Thank you
The ESC code was migrated from the original VGA client that Harrison wrote, and I've never
had issue with it. What pins is your keyboard located on?
OBC
I might have to try different pins on the prop.
I am using a Hybrid board.
Thank you
I tried a different pin however this didn't help.
I can get it to connect, set nick and then join #propeller. However after that no outgoing coms work.
Thank you
I'm not sure why the irc client isn't working for you. Your internet connection may be suffering packet loss, which can cause the tcp sockets code to fail. I'm still working on a fix for this.
Thanks to Harrison I have got my prop talking on IRC.
The keepalive code needed changing in order to get it to work.
Changing
to
Solved the problem.
Thank you Harrison
