Heat shrink transistions...yea a bit off subject
Thank you for all your help with the division problem...doing the binary division took care of the problem. So I have the project working perfectly on the bench...now I need to move forward and build looms. I need to find some 'y' and 't' heat shrink boots...sometimes referred to as transitions. I have found the Raychem and 3M transitions. Nice products..yet they are really proud of them. Are there any other manufactures of transitions?
thanks in advance
thanks in advance
If you don't have that problem, you might find it a lot cheaper to forgo them and just use straight runs with bare Ts and Ys. I suspect that these are provided for military spec and aeronautic industry uses - so they have a limited market and higher price. [noparse][[/noparse]It also takes a lot more tooling to make a shrinkwrap T or Y as it isn't a simple extrusion process.]
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
