Connecting Micro Motor Control To BS2
I have recently purchased the Micro Dual Serial Motor Control from Parallax. My question is after reading the PDF I downloaded from Parallax it shows a circuit to protect your PC if connecting directly to the serial port of a PC. Do I need to use the same protection when connecting to a BS2? If that circuit is not needed are there any other things I should consider when connecting to a BS2?
The Stamp already has logic level outputs and inputs. There are diagrams later in the Motor Controller documentation that show how to connect it to a microcontroller like a Stamp. There's also a sample BS2 program. Follow the directions in the documentation.
