Noobie Method Cog issues
Well Im back, the last bit of advice I got was awesome so thanks again.
So I cant seem to figure out why this wont work.
So my Tv out code is
Ok so this works for the most part, When I Compile and run this program it shows up on the TV with all values showing 0, Which makes sense to me.
Here is the issue when I call the method... I get nothing
Just a simple test program to call it
It does the same thing w/ or w/o variables or constants.
I know its probably something really stupid so sorry.
But I just cant seem to figure out why.
Thank you for your time.
TJ
''Motordisp.spin Take some Vars dump them on the screen CON _clkmode = xtal1 + pll16x _xinfreq= 5_000_000 OBJ TV : "TV_Terminal" VAR Long Stack[noparse][[/noparse]50] 'Stack space for a new cog. byte Cog PUB Start(RPMin, ADVin, Count): Success '' Start my new cog running this tv program Stop Success := (Cog := Cognew(Monitor(RPMin, ADVin, Count), @Stack) +1) PUB Stop '' Free the cog if Cog cogstop(Cog~ -1) PUB Active: YesNo ''Check the cog is active YesNo := Cog>0 Pub Monitor(RPMTime, Advance, Pulse) TV.start(12) '' Init my tv on pin 12 Repeat TV.Str(String("The RPM is ")) '' Print The RPM is TV.Dec(RPMTime) '' Print Var value TV.Out(13) '' New line TV.Str(String("The Advance is ")) '' Print The Advance is TV.Dec(Advance) '' Print Advance Value TV.out(13) '' New Line TV.Str(String("The Crank Pulse is ")) '' Print The Crank Pulse is tv.dec(Pulse) '' Print Pulse Value Tv.out(13) '' New Line Waitcnt(2_000_000 + cnt) '' Leave the info up a moment before clearing and Refreshing Tv.out(0) '' Clear Screen '' Do it forever....
Obj Disp : "MotorDisp" Con Pulse = 1000 RPM = 10 Pin = 20 Pub main Disp.start(Pulse,RPM,pin)
TJ
The TV object won't work with the default RCFAST values.
