You'd like something that would minimize the amount of noise picked up externally and between conductors in the cable.
One question is how many conductors you need. A lot of serial communication doesn't use the "handshaking" lines like
DTR and RTS. You may just need a ground, receive data, and transmit data. If you need handshaking, the specific signals
you need vary from device to device.
If you don't need handshaking, a simple cable with two twisted pairs would work well. One of each pair is used for the ground
connection.
If you need some handshaking lines, get a cable with twisted pairs for each line you need, again with one of each pair used for
the ground connections.
connection.
