Control HDD spindle motor
hi, i want to control a hdd spindle motor with a propeller.
the motor is(i believe) delta configuration with 4 connections:
phase 1
phase 2
phase 3
center/common
my design would involve connecting the center connection to V+(the motor voltage), and have the phases each connected to their own mosfet drain. all the sources would be connected to ground.
the mosfet gates would be connected to prop pins.
i would then control them with 3 shifting registers:
phase 1: 111000111000
phase 2: 001110001110
phase 3: 100011100011
what voltage should i run the motor on?
what current rating should the mosfets have?
what current rating should the protection diodes have?
the attached pic shows my circuit
I hear and I forget. I see and I remember. I do and I understand
-Confucius
phase 1
phase 2
phase 3
center/common
-Confucius
but i still need to know how much current these mosfets need to sink(and the diodes).
is it just as simple as going I = V/R?
7.06 = 12 / 1.7(the resistance of each coil measured with an ohm-meter)
i doubt it due to the whole induction thing(which i havent really looked into).
7.06 amps per phase?
im making a wall clock here, i dont want to have to power it with a car battery.
-Confucius
Post Edited (Lee Marshall) : 3/12/2008 6:44:39 PM GMT
Post Edited (mcstar) : 3/12/2008 8:49:21 PM GMT
