How to measure voltage???
I had a really good basic plan for a solar powered robot that would search for bright light when it sensed that it need to, but I need a way to measure voltage and get that as a value back to the board, so it will know when it needs to charge.
I don't know much about this and I really don't know how.
any help would be great.
thanks
thanks
thanks.
Now I'm considering more problems that I may encounter. (i'm still in the theoretical stage with my project.)
My idea is that when the robot senses low voltage, it will then find light meeting a certain threshold and stop. then the batteries will charge from the solar panels. BUT while there is power comming from both the batteries and the panel will it cause too much voltage to get to the BOE? I need to use a 6V battery and about a 6V input from the solar panel, i think.
ALSO, i think i need some sort of charge controller to prevent overcharging. but i can't find anything with a low voltage input such as my 6V panel.
is there any site or anything that can explain some of this to me?
Since this is purely theoretical, you may want to read about voltage regulators:
http://en.wikipedia.org/wiki/Voltage_regulator
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
use four of them (one in each direction) to detect which direction is brighter and move the robot in that direction.
photoresistors are dirt cheap, and most of the parallax kits come with at least one.
MORE SOLAR/ELECTRICAL QUESTIONS
I was thinking about using .1C to trickle charge the batteries as the robot just sits there. this is much more simple than other types of charging because it doesn't require a charge controller. (if this is a bad idea someone say so, but i can't find an approprite charge controller or solar panels capable of putting out descent currrent with 6V) a paper I read said that the boe bot's current drain is 300 mA.(is that accurate??) so if i use a 300 mAh battery does that mean that I need panels that produce 330A? (Boe-Bot's current + .1C of Battery)
as i said before I don't know much about electronics but this seems reasonable to me.
when I get this one issue cleared up I'll be ready to start
What you would like ideally is to have a solar panel that produces more current than the BoeBot draws when idle. It's that current that has to be less than the 0.1C of the batteries. The panels also have to be able to put out more voltage (when producing the charging current) than the battery produces. Good NiMH AA cells these days will have 2300-2700 mAh capacity which means that the 0.1C rate is 230-270 mA. If you have 5 cells (to produce 6V), you'll need a solar panel that'll produce about 1/4A at over 6V, so you're talking about at least a 1.5W panel. You don't need a charge controller because the panels won't produce more than about 0.1C and the BoeBot is drawing some of that current at idle. Don't forget that you'll need a series diode to prevent the BoeBot's batteries from discharging through the solar panel when the light level is low and that diode will cause some voltage drop (about 0.7V). Your panel should produce about 250mA at about 8V to allow for the diode and the peak battery voltage so it will be a 2W panel. The batteries will load the panel down to reduce the voltage to the 6-7V range.
Post Edited (Mike Green) : 3/16/2008 5:23:24 PM GMT
I had this hooked up through a diode to a 5cell NiMH battery pack (2300 mha) for a week on my back porch to see if it would be adequate to power a weather station I am building. I've attached the board layout and the results of the testing. It seemed to work well, but I determined I would need a larger battery to allow for several days of clouds and snow.
The first four days were clear and sunny, but the last three were overcast and raining. The final day did have a little sun, but not enough to recharge the battery to a level that would last the night. Based on the final days of the test, I determined that the 2300 mha would not be adequate to keep the system going. The final battery selection was a 10000 mha battery (http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=1482). This unit also has a built in thermal protection switch which will disconnect the batteries if they start to get overcharged.
I've also attached the code to read the battery and solar panel outputs. U1 and U2 are ADC0831 and the bluetooth connection was a A7 eB501-SER.
Post Edited (MSDTech) : 3/17/2008 12:08:41 PM GMT
That look real nice
You have this Project·layed out very well and you done your home work on your Project
Thank You for the link for the Solar Panels I sure can use some of those panels
··Thanks for any·
Sam
