Question about chip enable circuitry on 3-to-8 decoder
I have a question about decoders. Lets assume for the remainder of this post and all subsequent posts in this topic that I am using a 3-to-8 decoder/demux with with standard A, B and C chip select inputs but also 3 enable inputs labeled G1(drive high), G2A(drive low) and G2B(drive low).
The enable inputs must be driven low or high·according to what I said above, and according to their schematics, you should use·additional·address bus lines to drive the lines. Wouldn't it·be better to conserve·precious address lines by simply using the VCC line to drive the enable inputs high and connecting the enable inputs that·need to be driven low by grounding them? If my description was to confusing, here is the datasheet of the product I plan on using as an address decoder:
http://focus.ti.com/lit/ds/symlink/74ac11138.pdf
One of the reasons I came up with that was that VCC is considered logical 1, or high while VSS is considered logical 0, or low.
Also, as a side question, is it alright on the PCB·design and schematic·to connect multiple chips to the same wire for data transfer to the Propeller? E.g. connecting 3 serial EEPROMs in a chain to the pins I program to accept serial data on the processor or the address lines in a chain to the processor? Thanks,
Nick
Nick
On your side question. You could connect multiple chips on the same line as long as they're meant for that sort of use. They would need to be open collector/drain or perhaps tri-state-able with the output enable lines controlled somehow so only one chip can attempt to drive the line at one time. If more than one chip can drive the line in opposite directions, you'll burn out one or both of them with the short circuit.
I want to use multiple connections to single wires because I want to use a serial "channel" based I/O scheme, e.g.
Channel 1: Program ROM & Media ROM
Channel 2: Main RAM
Channel 3: Second Propeller
So on and so on. RAM and ROM will require Chip enable signals, hence my use of 3-to-8 decoders. I just have to be really careful not to allow 2 devices to drive any "channel" in opposite directions at the same time.
Post Edited (nick112147) : 3/11/2008 2:42:24 AM GMT
