C# Basic Stamp Tokenizer Class
Here's what I've got so far;
But I'm having trouble making calls to the TestAlign functions and Compile Functions. I think I'm not marshalling properly?
I try:
And it just fails. Anyone have ideas?
SharpStamp.cs
I try:
IntPtr RecPtr = IntPtr.Zero;
IntPtr TokPtr = IntPtr.Zero;
Stamp.TModuleRec myRec = new Stamp.TModuleRec();
RecPtr = Marshal.AllocCoTaskMem(4);
Marshal.StructureToPtr(myRec, RecPtr, true);
Stamp.tokenizer_test_align(ref RecPtr);
SharpStamp.cs
using System;
using System.Collections.Generic;
using System.Text;
using System.Runtime.InteropServices;
namespace CSStampServer
class Stamp
/// <summary>
/// The value returned is in the format: XYY ;where X is the major version number and Y is the minor.
/// For example, if the Version function returned 116, that indicates the version of the tokenizer is 1.16.
/// If Version returned 123, that would indicate the tokenizer is version 1.23.
/// </summary>
/// <returns></returns>
[noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "Version")]
public static extern int tokenizer_version();
/// <summary>
/// Tests the alignment and sets values to, 0, 1, 2, 3, ... 32.
/// </summary>
/// <param name="Rec"></param>
[noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "TestRecAlignment")]
public static extern bool tokenizer_test_align(ref IntPtr /* TModuleRec* */ Rec);
/// <summary>
/// /// The Compile function for the basic stamp tokenizer.
/// </summary>
/// <param name="Rec">A pointer to an existing TModuleRec structure.</param>
/// <param name="Src">A pointer to an existing Source buffer.</param>
/// <param name="DirectivesOnly">A Boolean value that provides an option of only tokenizing the “compiler directives” from the source code, rather than the entire source.
/// This option is helpful when the calling program needs to determine only the target module, serial port or project files that may be specified by the PBASIC source code.
/// TRUE : Causes the tokenizer to only parse the directives from the source code.
/// FALSE : (Normal mode) Causes the tokenizer to parse the entire source code, including all directives (depending on the ParseStampDirective parameter).</param>
/// <param name="ParseStampDirective">A Boolean value that provides an option of parsing the Stamp directive from the source code, rather than accepting a value in the TargetModule field of the TModuleRec structure.
/// TRUE : (Normal mode) Causes the tokenizer to parse the Stamp directive, if present, from the source code.
/// If a valid directive is found, the compiler stores the value of the target module in the TargetModule field and compiles. If no Stamp directive is found, the tokenizer generates an error.
/// FALSE : Causes the tokenizer to ignore any Stamp directives in the source and instead use the value currently in the TargetModule field to compile the code.
/// This means, the TargetModule field MUST be set to the proper value BEFORE calling Compile.</param>
/// <param name="Ref">An optional pointer to an existing TSrcTokReference buffer. Set to NULL when not used.</param>
[noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "Compile")]
public static extern bool tokenizer_compile(IntPtr /* TModuleRec* */ Rec,
[noparse][[/noparse]MarshalAs(UnmanagedType.LPStr)]IntPtr /* char* */ Src,
[noparse][[/noparse]MarshalAs(UnmanagedType.Bool)]bool DirectivesOnly,
[noparse][[/noparse]MarshalAs(UnmanagedType.Bool)]bool ParseStampDirective,
IntPtr /* TSrcTokReference* */ Ref);
#region Unmanaged Structs Implementation
[noparse][[/noparse]StructLayout(LayoutKind.Sequential)]
internal struct STAMP_IF
public IntPtr /* TSrcTokReference* */ SrcTokenReference;
public string Name;
public string Decription;
public IntPtr /* TModuleRec* */ TokenModule;
/// <summary>
/// This structure is optional since it is intended for use by PBASIC simulators.
/// </summary>
internal struct TSrkTokReference
[noparse][[/noparse]MarshalAs(UnmanagedType.U2)]
public ushort SrcStart;
public ushort TokStart;
/// <summary>
/// This is the structure that is used for the Basic Stamp Tokenization process. (The information sent to the Compiler.)
/// </summary>
internal class TModuleRec
public bool Succeeded;
public string Error;
public bool DebugFlag;
public byte TargetModule;
public int TargetStart;
[noparse][[/noparse]MarshalAs(UnmanagedType.ByValArray, SizeConst = 7)]
public IntPtr[noparse][[/noparse]] /* char** */ ProjectFiles;
public IntPtr[noparse][[/noparse]] /* int* */ ProjectFilesStart;
public string Port;
public int PortStart;
public int LanguageVersion;
public int LanguageStart;
public int SourceSize;
public int ErrorStart;
public int ErrorLength;
[noparse][[/noparse]MarshalAs(UnmanagedType.ByValArray, SizeConst = 2048)]
public byte[noparse][[/noparse]] EEPROM;
public byte[noparse][[/noparse]] EEPROMFlags;
[noparse][[/noparse]MarshalAs(UnmanagedType.ByValArray, SizeConst = 4)]
public byte[noparse][[/noparse]] VarCounts;
public byte PacketCount;
[noparse][[/noparse]MarshalAs(UnmanagedType.ByValArray, SizeConst = 2304)]
public byte[noparse][[/noparse]] PacketBuffer;
#endregion
public static string Version
get
try
return tokenizer_version().ToString();
catch
return "Parallax Tokenizer version can't be identified or the tokenizer.dll is not installed.";
TModuleRec and it thus gets missaligned. Fill your TModuleRec structure with characteristic values and check the memory layout with the
debugger or a hexdump.
Hope it helps.
Adrian
Here's my example:
public unsafe void TestRecAlign() { //Verify Stamp Record Alignment (TestAlignRec) fixed (Stamp.TModuleRec* p = &myRec) { if (Stamp.tokenizer_test_align(p) == true) { int i = 0; richTextBox1.Text = "Test align returned true" + Environment.NewLine + Environment.NewLine; richTextBox2.Text = "Values are..." + Environment.NewLine; richTextBox2.Text += "Succeeded: " + p->Succeeded.ToString() + Environment.NewLine; richTextBox2.Text += "Error: " + p->Error.ToString() + Environment.NewLine; richTextBox2.Text += "DebugFlag: " + p->DebugFlag.ToString() + Environment.NewLine; richTextBox2.Text += "TargetModule: " + p->TargetModule.ToString() + Environment.NewLine; richTextBox2.Text += "TargetStart: " + p->TargetStart.ToString() + Environment.NewLine; for (i = 0; i < 6; i++) { richTextBox2.Text += "ProjectFiles[noparse][[/noparse]" + i.ToString() + "]: " + Marshal.PtrToStringAnsi((IntPtr)p->ProjectFiles[i]) + Environment.NewLine; } for (i = 0; i < 6; i++) { richTextBox2.Text += "ProjectFilesStart[noparse][[/noparse]" + i.ToString() + "]: " + p->ProjectFilesStart[i].ToString() + Environment.NewLine; } richTextBox2.Text += "Port: " + Marshal.PtrToStringAnsi(p->Port) + Environment.NewLine; richTextBox2.Text += "PortStart: " + p->PortStart.ToString() + Environment.NewLine; richTextBox2.Text += "LanguageVersion: " + p->LanguageVersion.ToString() + Environment.NewLine; richTextBox2.Text += "LanguageStart: " + p->LanguageStart.ToString() + Environment.NewLine; richTextBox2.Text += "SourceSize: " + p->SourceSize.ToString() + Environment.NewLine; richTextBox2.Text += "ErrorStart: " + p->ErrorStart.ToString() + Environment.NewLine; richTextBox2.Text += "ErrorLength: " + p->ErrorLength.ToString() + Environment.NewLine; richTextBox2.Text += "EEPROM: "; for (i = 0; i < 2048; i++) { richTextBox2.Text += p->EEPROM[i].ToString(); } richTextBox2.Text += Environment.NewLine; richTextBox2.Text += "EEPROMFlags: "; for (i = 0; i < 2048; i++) { richTextBox2.Text += p->EEPROMFlags[i].ToString(); } richTextBox2.Text += Environment.NewLine; for (i = 0; i < 3; i++) { richTextBox2.Text += "VarCounts[noparse][[/noparse]" + i.ToString() + "]: " + p->VarCounts[i].ToString() + Environment.NewLine; } richTextBox2.Text += "PacketCount: " + p->PacketCount.ToString() + Environment.NewLine; richTextBox2.Text += "PacketBuffer: "; for (i = 0; i < 2304; i++) { richTextBox2.Text += p->PacketBuffer[i].ToString(); } richTextBox2.Text += Environment.NewLine; return true; } else { return false; } } }[/i][/i][/i][/i][/i][/i]For -calling- the rec align function, the actual struct (and all of the background stuff), is declared as follows;
class Stamp { /// <summary> /// The value returned is in the format: XYY ;where X is the major version number and Y is the minor. /// For example, if the Version function returned 116, that indicates the version of the tokenizer is 1.16. /// If Version returned 123, that would indicate the tokenizer is version 1.23. /// </summary> /// <returns></returns> [noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "Version")] public static extern int tokenizer_version(); /// <summary> /// Tests the alignment and sets values to, 0, 1, 2, 3, ... 32. /// </summary> /// <param name="Rec"></param> /// <returns></returns> [noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "TestRecAlignment")] public unsafe static extern bool tokenizer_test_align(TModuleRec* /* TModuleRec* */ Rec); /// <summary> /// /// The Compile function for the basic stamp tokenizer. /// </summary> /// <param name="Rec">A pointer to an existing TModuleRec structure.</param> /// <param name="Src">A pointer to an existing Source buffer.</param> /// <param name="DirectivesOnly">A Boolean value that provides an option of only tokenizing the “compiler directives” /// from the source code, rather than the entire source. /// This option is helpful when the calling program needs to determine only the target module, serial port or /// project files that may be specified by the PBASIC source code. /// TRUE : Causes the tokenizer to only parse the directives from the source code. /// FALSE : (Normal mode) Causes the tokenizer to parse the entire source code, including all directives /// (depending on the ParseStampDirective parameter).</param> /// <param name="ParseStampDirective">A Boolean value that provides an option of parsing the Stamp directive /// from the source code, rather than accepting a value in the TargetModule field of the TModuleRec structure. /// TRUE : (Normal mode) Causes the tokenizer to parse the Stamp directive, if present, from the source code. /// If a valid directive is found, the compiler stores the value of the target module in the TargetModule /// field and compiles. If no Stamp directive is found, the tokenizer generates an error. /// FALSE : Causes the tokenizer to ignore any Stamp directives in the source and instead use the value /// currently in the TargetModule field to compile the code. /// This means, the TargetModule field MUST be set to the proper value BEFORE calling Compile.</param> /// <param name="Ref">An optional pointer to an existing TSrcTokReference buffer. Set to NULL when not used.</param> /// <returns></returns> [noparse][[/noparse]DllImport("tokenizer.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall, EntryPoint = "Compile")] public unsafe static extern bool tokenizer_compile(TModuleRec* /* TModuleRec* */ Rec, [noparse][[/noparse]MarshalAs(UnmanagedType.LPStr)] string Src, bool DirectivesOnly, bool ParseStampDirective, TSrkTokReference* /* TSrcTokReference* */ Ref); #region Unmanaged Structs Implementation [noparse][[/noparse]StructLayout(LayoutKind.Sequential)] internal struct STAMP_IF { public IntPtr /* TSrcTokReference* */ SrcTokenReference; public string Name; public string Decription; public IntPtr /* TModuleRec* */ TokenModule; public SerialPort serialPort; public int /* Port for remoting */ remotePort; } /// <summary> /// This structure is optional since it is intended for use by PBASIC simulators. /// </summary> [noparse][[/noparse]StructLayout(LayoutKind.Sequential, CharSet = CharSet.Ansi)] unsafe internal struct TSrkTokReference { public ushort SrcStart; public ushort TokStart; } /// <summary> /// This is the structure that is used for the Basic Stamp Tokenization process. /// (The information sent to the Compiler.) /// </summary> [noparse][[/noparse]StructLayout(LayoutKind.Sequential, CharSet = CharSet.Ansi, Pack = 4)] unsafe internal struct TModuleRec { public byte Succeeded; /*Is a bool*/ public IntPtr Error; /* Marshal to AnsiString */ public byte DebugFlag; /*Is a bool*/ public byte TargetModule; public int TargetStart; public fixed int ProjectFiles[noparse][[/noparse]7]; /* Cast To IntPtr */ public fixed int ProjectFilesStart[noparse][[/noparse]7]; public IntPtr Port; /* Marshal to AnsiString */ public int PortStart; public int LanguageVersion; public int LanguageStart; public int SourceSize; public int ErrorStart; public int ErrorLength; public fixed byte EEPROM[noparse][[/noparse]2048]; public fixed byte EEPROMFlags[noparse][[/noparse]2048]; public fixed byte VarCounts; public byte PacketCount; public fixed byte PacketBuffer[noparse][[/noparse]2304]; } #endregion public static string Version { get { try { return tokenizer_version().ToString(); } catch { return "Parallax Tokenizer version can't be identified or the tokenizer.dll is not installed."; } } } }I'll try to get this actually wrapped into an entire library with collections so that if other people want to use the tokenizer in C# they can!
