X10 Firecracker RF transmitter to 220V receiver?
I've successfully combined the X10 Firecracker module with a BS2 device.· Things work pretty amazingly:· The Firecracker transmits RF to the 110V RF receiver module, which also has an outlet on it, and thus the BS2 can control the load attached to the receiver.
I have a simple followup need:· I want to use the same device (BS2 , X10 Firecracker RF transmitter, etc.) to "talk" to an X10 receiver in Europe.· I've spoken to X10 and I they don't seem to understand that this should have NOTHING to do with mixing US/Europe 110V/220V wiring/infrastructure/60Hz, etc. (there's no reason why the RF signals used by Firecracker can't be used anywhere in the world; those transmissions simply have to be heard and acted upon by a receiver that's 220v-friendly; or am I missing something?)
Given the above clarify (hopefully), does anyone have any ideas?· I need a receiver that can listen for and act upon the X10 Firecracker RF transmissions (and I don't need any other device on the electrical wiring to be controlled!)
This is a followup to my original post (http://forums.parallax.com/showthread.php?p=712427) since that post was a combination of several issues and went on to be confusing and tangential.
Andy
Andy
I guess I don't understand why you didn't just do a web search. Here's one link I found on Google with "x10 europe": www.x10europe.com/pdf/TM13E.pdf.
Post Edited (Mike Green) : 3/10/2008 5:25:49 PM GMT
- Stephen
BS2 -> Firecracker -> RF -> Wall device with antenna -> power-line -> Controlled X10 box.
Okay, so you want to move this to europe. Well, it sounds like the above TM13E replaces the above "Wall device with antenna", which WILL recieve the Firecracker RF signal, so you should be good to go from that point on.
No products sold via the US website can control the TM13E. The TM13A only responds to commands at 418MHz; all US X10 home automation remotes work at 310MHz.
http://www.google.com/search?q=hr12e
If you have any more questions, please reply to this email. Thanks for choosing X10!
Eric Boyd | ericb@x10.com | X10 Email Support | http://kbase.x10.com/
The TM13E spec sheet says,
"A built-in appliance switched outlet responds to X10
signals received on the power line or to RF signals
received from any X10 wireless remote controls."
So that's why I'm confused.
"X10.com does not sell ANY products that can talk via RF to European X10 receivers. All US RF products are 310MHz; all European ones use 418MHz.
I'd look here for workarounds: http://idobartana.com/hakb/index.htm
So, you need a european compatible Firecracker -- it's not like they're expensive, after all.
Yes, I do need it to be wireless/RF, just like my US unit.· And problem is not cost of buying another Firecracker for Europe.· Problem is that the Europe Firecracker is a huge box that sits on an outlet.· What I have now is totally different -- a tiny DB9 "matchbox" that sits inside my project box, connected to a BS2, that can control lights and appliances throughout the room!!!
Still stuck with no solution, and very frustrated when things have to be so difficult and incompatible once you cross the country boundary.
See attached spec sheets.
Andy
Mike may be onto your best solution: hack one of the keyfob remotes to simulate button presses.
http://www.home-control.co.uk/index_products.php?page=default.php&manufacturers_id=8&osCsid=c2e6be32acbf87211b637a2581022f1f
