Charging a 1.2V NiMH battery
I would like to write a code using BS2 to monitor the battery voltage. Whenever it charge to the max level (1.5V), then I will cut it off.· I'm a new user....any idea is very appreicated.
thanks
thanks
It describes the characteristics of NiMH batteries and the factors to consider when charging them. Not only should you monitor the batteries voltage, you also need to monitor the temperature change as the battery is charging.
