help with a circuit for a high voltage/current 7-segment display
Hello everyone,
I am using a BS2 to run two 4511 binary-to-digital converter chip to display numbers up to 99 on a high voltage/current dual 7-segment display board.
The problem is the display only works with voltages higher than 9 volts and the 4511 can only push 5 volts and low current.
Does anyone out there know the best way to use transisters in this circuit so:
1.· I can get the transistor circuit to trigger off the 0 to 5 volts without·burning up the 4511 chip or my BS2 chip in the process!!!!
A circuit diagram would be helpful if you already have one or can put one together.
I have tried this circuit with the NPN transisters but I ended up frying the 4511 chip and luckily didn't get my BS2 chip.
Thanks for any help!!
Joe
Joe
Without more information from you about your display, it's impossible to provide a circuit diagram or anything more detailed since you've left so much unspecified.
The display is a [noparse][[/noparse]4] segment display from Maxx Tronic MX006-1 led display
MX034: SEVEN SEGMENT DISPLAY 3” (Standard·LEDs)
Detail:
-Display dimensions : 46x75 mm. or 1.78x3 inch.
-PCB dimensions : 63x85 mm. or 2.5x3.3 inch.
-Power supply : 12 Vdc.
-Display used : Ultra-bright LEDs.
-Consist : 5 LED’s per segment and a LED’s for the decimal point (p).
-At 12Vdc. A segment current ~ 15 mA.
15mA.»A decimal point (p) current ~
Total current ~ 120mA.
Fully Assembled and Tested
“Intellectual growth should commence at birth and cease only at death”
Albert Einstein
