Newbie curious about environmental affects of SX chips
I'm a BASIC Stamp user about to switch to SX chips for an important
out door project. Before I do so I'd like to make sure that the SX
and the SX28 protoboard can handle the environment.
I live in the smokey mountains, and temps can range from·0 degrees F
to up to 100f. The moisture is usually 80-100% and raining for a week
straight is common.
If I put the SX28 in a sealed case, can it handle those environmental
situations?
Besides a watertight container, are there any special considerations I'll
have to make for an SX project?
straight is common.
situations?
If the box itself will be sitting in the hot sun, more active cooling methods, such as a Peltier device, may be needed. The other option would be just to monitor the temperature and program the system to shut itself off if it gets too hot.
activate a relay.
