reading measurments off hitachi hm55b compass module and writing to usb data lo
How can i change the code below to read an angle measurement from a Hitachi hm55b compass module? The compass module is connected to a BS2 Basic stamp and the angle measurement is "outputed" from one of the I/O pins. Thanks.
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' Before running this program be sure your Memory Stick Datalogger is
' connected as per the Quick Start Circuit in the documentation and that
' a formatted USB Thumb Drive is connected to the USB connector.
' This program tests the Memory Stick Datalogger (#27937) by writing data
' to a connected USB Thumb Drive. First a file called, 'SEEDFILE.TXT' is
' created to hold the seed value for generating sets of 5 random numbers.
' The random numbers are stored in a file called, 'DATAFILE.TXT' which is
' stored in a sub-folder called, 'DATADIR' on the drive. Once data has
' been stored on the drive it can be connected to a PC and read. Data
' could be formatted during writes in a format that allows it to be loaded
' into a spreadsheet and charted or graphed.
' NOTE: The drive is put into Standby (Sleep) Mode for ~10 seconds between
' writes. This is a good time to turn off the power and disconnect the
' drive from the Datalogger. You should not disconnect the drive while
' the Datalogger is writing to it or the data and/or file/folder structure
' could be corrupted. For troubleshooting see the documentation.
[noparse][[/noparse] I/O Definitions ]
TX PIN 8 ' Transmit Data --> 27937.4 (RXD)
RTS PIN 9 ' Request To Send --> 27937.6 (CTS)
RX PIN 10 ' Receive Data <-- 27937.5 (TXD)
CTS PIN 11 ' Clear To Send <-- 27937.2 (RTS)
[noparse][[/noparse] Constants ]
Baud CON 84 ' Serial Baud Rate 9600 bps (BS2)
[noparse][[/noparse] Variables ]
timeout VAR Bit ' Timeout Inidicator
buffer VAR Byte(15) ' Input Buffer
index VAR Byte ' Index Variable
ioByte VAR Byte ' Input/Output Storage
temp VAR Byte ' Temp Variable
counter VAR Word ' Counter Variable
result VAR Word ' Random Number Storage
[noparse][[/noparse] Initialization ]
DEBUG CLS, "Memory Stick Datalogger Test V1.0", CR, CR
PAUSE 2000 ' Allow Time To Settle
HIGH TX ' Initialize Transmit Line
LOW RTS ' Take Vinculum Out Of Reset
GOSUB Purge ' Purge Buffer
DEBUG "Synchronizing...", CR
index = 0
' For Synchronization send E until echoed back
DO WHILE (index < 1)
PAUSE 250
SEROUT TX\CTS, Baud, [noparse][[/noparse]"E", CR] ' Transmit "E CR"
GOSUB Get_Serial_Bytes ' Get Returned Data
LOOP
' Send e to complete synchronization
PAUSE 500
SEROUT TX\CTS, Baud, [noparse][[/noparse]"e", CR] ' Transmit "e CR"
' Send CR to see if drive is present
PAUSE 500
DEBUG "Checking for USB Flash drive...", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]CR] ' Send Carriage Return
GOSUB Get_Serial_Bytes ' Wait for
IF (buffer(0) = "N") THEN
DEBUG "No drive present!"
STOP
ELSE
DEBUG "Drive
Ready...", CR
ENDIF
[noparse][[/noparse] Program Code ]
Main:
result = 11000 ' Initial "seed" Value For Random
RANDOM result ' Generate Random Number
DEBUG "Random Number (Seed) = ", DEC result, CR
' Delete SEEDFILE.TXT if one exists, ignore error if no file exists
PAUSE 500
SEROUT TX\CTS, Baud, [noparse][[/noparse]"DLF seedfile.txt", CR]
' Open SEEDFILE.TXT for output (write)
PAUSE 250
SEROUT TX\CTS, Baud, [noparse][[/noparse]"OPW seedfile.txt", CR]
' Write random seed value to SEEDFILE.TXT
PAUSE 250
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WRF ", $00, $00, $00, $05, CR, DEC5 result, CR]
' Close SEEDFILE.TXT
PAUSE 250
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CLF seedfile.txt", CR]
' Create folder DATADIR and ignore error if folder exists
PAUSE 200
SEROUT TX\CTS, Baud, [noparse][[/noparse]"MKD datadir", CR]
counter = 0 ' Loop Counter
DO
' Open SEEDFILE.TXT for input (read)
PAUSE 200
SEROUT TX\CTS, Baud, [noparse][[/noparse]"OPR seedfile.txt", CR]
' Read random seed into variable
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"RDF ", $00, $00, $00, $05, CR]
SERIN RX\RTS, Baud, 500, No_Data2, [noparse][[/noparse]DEC5 result]
DEBUG "Seed:", DEC result, CR ' Display stored seed value
PAUSE 120
' Change to DATA folder
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CD datadir", CR]
' Open DATAFILE.TXT for output (write)
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"OPW datafile.txt", CR]
counter = counter + 1 ' Increment Counter
' Write loop counter value and data separator to DATAFILE.TXT
PAUSE 120
DEBUG "Writing data separator now... ", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WRF ", $00, $00, $00, $09, CR,
DEC5 counter, "**", CR, LF, CR]
' Write 5 random numbers to DATAFILE.TXT
PAUSE 120
DEBUG "Writing 5 random numbers now... ", CR
FOR temp = 1 TO 5
RANDOM result
DEBUG "Random Number = ", DEC result, CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WRF ", $00, $00, $00, $07, CR,
DEC5 result, CR, LF, CR]
PAUSE 120
NEXT
' Close DATAFILE.TXT
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CLF datafile.txt", CR]
' Change to root folder
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CD ..", CR]
PAUSE 120
PAUSE 120
' Write new random seed value
PAUSE 120
PAUSE 120
' USB Suspend Mode (Power Saving Mode)
PAUSE 120
DEBUG "Putting drive to sleep...", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"SUD", CR]
PAUSE 10000
' Wake Drive (Full Power)
PAUSE 120
DEBUG "Waking drive now", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WKD", CR]
LOOP
[noparse][[/noparse] Subroutines ]
Get_Serial_Bytes:
timeout = 1 ' Set Timeout Indicator Flag
index = 0 ' Initialize Index
DO WHILE (timeout > 0) ' While Timeout Has Not Occurred
ioByte = 0 ' Clear Temporary Storage
SERIN RX\RTS, Baud, 100, No_Data, [noparse][[/noparse]ioByte]
buffer(index) = ioByte ' Save Byte Received To Array
index = index + 1 ' Increment Index
IF (index > 14) THEN ' Check For Overflow
index = 14 ' Prevent Overflow
ENDIF
LOOP
RETURN
Purge:
PAUSE 50
SERIN RX\RTS, Baud, 500, No_Data, [noparse][[/noparse]ioByte]
LOOP
RETURN
No_Data:
timeout = 0 ' Timeout, Clear Flag
RETURN
No_Data2:
DEBUG CR, "Error reading the seed file -- Halting execution!", CR
PAUSE 1000
STOP
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
index = 0
PAUSE 250
LOOP
PAUSE 500
PAUSE 500
STOP
ELSE
DEBUG "Drive
ENDIF
Main:
PAUSE 500
PAUSE 250
PAUSE 250
PAUSE 250
PAUSE 200
DO
PAUSE 200
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
FOR temp = 1 TO 5
RANDOM result
PAUSE 120
NEXT
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 120
PAUSE 10000
PAUSE 120
LOOP
Get_Serial_Bytes:
ENDIF
LOOP
RETURN
Purge:
PAUSE 50
LOOP
RETURN
No_Data:
RETURN
No_Data2:
PAUSE 1000
STOP
RETURN
- Stephen
