can we make our pink module wireless ?
hi ,,
our mini project is control servos ,we had successfully completed first phase,,
later we thought hope we can any wireless system so that it would be better , is there any method so that we can make pink module wireless get rid of that cat5 blue cable
>any modules available in the market?
>if so what is the cost
>any additional coding is required
trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=3
Here is my test set up:
- Rick
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
The thing that would concern me about mobile use is power consumption. It runs off one of those small regulated switch-mode AC adapters that's rated 7.5 v@1 amp. The router itself gets kind of warm on the bottom, so I suspect it may be a bit power hungry. Of course, the PINK is no power miser either.
The TrendNet device was not terribly expensive, it was about $45 including shipping.
edit: If I can find the time, I'll open it up and see what's inside and also measure how much power it uses.
- Rick
Post Edited (RDL2004) : 3/8/2008 11:36:47 PM GMT
There is one on ebay - here
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
if so how can we reconfigure the pink module ?
To the PINK module, this looks just like a router.
