Full Screen Text Editor *fixed* (and moving toward expansion)
Oldbitcollector (Jeff)
This is version 1.2 of a text editor for the Propeller, intended as an add-on
tool for PropDos users. Launching the Propedit will allow you to create/load/save
text files. This version is limited to a single page of text, but that will be increased
in later revisions. Think of this as NOTEPAD for PropDOS.
This version has squashed the major bugs which prevented it from being useful.
I'm working on a few more cursor rule adjustments for the next release, but it
is now a *working* editor.
Give it a spin and let me know.
Edit Added:
A mutli-page version of this editor is also attached (Version 1.3b)
It is in Alpha, so I'm still bug chasing.. but it supports up to five pages of text.
Version 1.3b has most of the load/save bugs worked out.
OBC
rename with .zip extension
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Post Edited (Oldbitcollector) : 7/29/2008 2:42:31 AM GMT
Edit Added:
OBC
Paul Baker
A long overdue PropDOS update is also in the works....
*removal of PropCOMM (moved to separate file)
*addition of "DOS-like" execution of .bin files. (no more typing 'spin filename.bin')
OBC
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Post Edited (Oldbitcollector) : 3/8/2008 8:35:02 AM GMT
Fixed and attached to top thread..
OBC
Keyboard pin in I/O settings for Hydra board needs to be 13 instead of 12.
Thanks. I think I have it right now.
Did some edits to improved switching between the editor and menu screen.
[noparse][[/noparse]ESC] now toggles between them. Loading a file now loads and takes you to
the editor. Also I've added a DIRECTORY command.
Interface feels more natural to use now..
OBC
Love the avatar - I've got two boys about that age - trying that and worse !!
'Necessity is the mother of invention'
Took your Text Editor for a quick spin today. I had to change the Keyboard pin back to 12 for use on a Hybrid. If left as 13 all keyboard LEDs just flash and no key input is possible. A very nice text editor, that should suddenly find many uses.
I did think of a possible upgrade to the Aigeneric TV driver, the ability to load a font stored on SD card instead of this being hard coded. Obviously you need something to
start off with (reference to this file stored in eeprom) select a new font set, also save this reference to eeprom then reboot. I see complications to this scheme, which looked great on paper. Did also think about a fixed status bar showing the X and Y information for the current cursor position, amongst other things.
Another nice project from the OBC collection!!
With regards
Mike.
Sigh.. Can't keep track of my own releases..
If I haven't posted it, I will dig it up and see if I remember why.
OBC
I've known about this program for a while but havn't tried it yet.
Share the knowledge: propeller.wikispaces.com
Lets make some music: www.andrewarsenault.com/hss
This is a version of PropEDIT (CGEdit) which will allow you to load 64c fonts from the SD.
While it works, it's considered unfinished as it doesn't support font color. *yet [noparse]:)[/noparse]
OBC
(Perhaps a few more brains involved will be able to do more...)
I'm posting this because "stevenmess2004" asked, and I thought it belonged in it's own thread.
Here goes..
This Full Screen Editor grabs all keystokes (other than cursor controls) and keeps track in screen[noparse]/noparse.
As a result, all keystrokes are displayed on screen immediately.
When the file is saved, (and here's where I *think* the bug is, the empty spots are fulled with spaces)
and the file is written to the SD.
Another mystery is why normal text files are unable to load properly, but I suspect issues along
the same vein.
I think this could become a very powerful editor for the Prop, but it's going to require more
programming experience than I currently have myself...
OBC
When you wanted to save or load something you just need to use the text buffer and not the display buffer which should be a lot easier. Also, if you filled the text buffer with spaces it should same you some other hassles.
You could set the assembly driver to either continually update the display buffer or to just update when asked to (say whenever a key is pressed). Also, you could make the assembly driver so that it started at some arbitrary place in the buffer and then you would be able to have more than one screen.
Well I just had a better look at your code and it looks like you are already doing half of what I suggested so its probably not all that useful...
i wouldn't update the screen except when its edited though, and then only the line of the screen the cursor is on. doing it that way probably wouldn't require ASM
keyboard = 12 '' I/O for keyboard connection ' (changed it from 13) keyboard = 13 '' I/O for keyboard connection
Unfortunately my HD card quit a few days ago & therefore, I could not test that part of the program.
Aka: CosmicBob
I was fiddling with notepad while working on another project..
A corrected release will be uploaded in a day to so..
Funny how the brain works..
OBC
Still can't believe I didn't see this till now. (Been bugging me for months!)
OBC
so it doesn't save anything. What our programs both lack is certain keys such as insert and delete which should be
easy if we can find the cursor locations and use BYTEMOVE.
BYTEMOVE is probably also the key to scrolling and having a larger text file, by simple transfers between the
screenbuffer and a textfile in RAM when you push the cursor past the vertical edges of the screen.
I doesn't scroll *YET* and has a couple issues I'm chasing down,
but is another step in the right direction..
(Attached to the top thread)
Ok guys, we have a primitive text editor for the Propeller, now we need
some sort of compiler and we can move toward ditching Proptool, and
developing apps on the Prop itself...
OBC
http://forums.parallax.com/showthread.php?p=692011
If anyone wants to play with it, I have a partially written Basic to LMM binary compiler using a lot of the same code. I ran out of space and plan to split it up into passes when I have some time to work on it this Fall.
I'd love to play with that if you don't mind sharing..
OBC
Just for the fun of it I added Phils cool phonemic voice synthesizer.
Here's the related discussion of his work:
http://forums.parallax.com/showthread.php?p=613308
Press F9 in main menu to have the text read to you.
Makes it a lot·easier to try out different ways to write words to get them to sound right without having to compile a lot, doesn't it?
Start with "#1aybee+7seedee++ee ef--jee"
I go to bed after submitting a text editor and wake up with a speech toy!
Collaborative projects are just awesome! Looking forward to playing with this later.
A question, did you notice that blank spaces are 1's and carriage returns are not 3's not 13.
Edit:
Actually this might even be nicer to add to version 1.3a as I update @screen on every pass
and F9 could just be added to the editor. Neat Idea!
#0eigh--#2eigh--#1eigh--#3eigh-- heh..
OBC
Post Edited (Oldbitcollector) : 7/27/2008 3:43:20 PM GMT
F9 now·speaks the text in editing mode also.
Now I have to do some character remapping, I'm using a german keyboard and finding those special characters on it is a pain...
Um, not really, no,·I didn't look at the code very closely, just pasted some lines from the talking demo.
Cheers,
Clemens
I've attached 1.3b to the top of the thread.. It's a bit more stable in LOAD/SAVE.
It's dropping a character at the very end of each page, but it's close enough to be
useful as a multi-page editor.
Edit: Bah! New bug found, not saving files as truly DOS compatible.
I'll have this straightened out in a day or two. Then you'll be able to edit Femto files
as well.
I was day-dreaming the other day... What if we created a webserver running Propellant
that could receive a .spin file and send back binary? Wouldn't remove the PC entirely,
but it could make things interesting for those with a PropNIC. (or equiv)
OBC
Post Edited (Oldbitcollector) : 7/29/2008 3:41:12 AM GMT
This program could be just perfect for editing small autoexec and batch files that you can leave on the sd card and change settings without having to recompile spin programs. Useful for 'out in the field' applications.
www.smarthome.viviti.com/propeller
I dropped the project after mparks editor was released, but for the life of me I can't find the thread.
Also Casslan did an excellent editor as well.
OBC
Propeller Feature Projects: PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
