Here's Blowfish (I don't know where Hootie is) — Parallax Forums
Paul BakerPaul Baker Posts: 6,351
edited 2009-05-23 21:54 in Propeller 1
In order to understand the encryption algorithm Blowfish, I ported the reference code into Spin. The algorithm has been verified through test vectors. Current execution speed for initialization is just over 1 second. Each encrypt/decrypt function takes just under 2 ms to execute for a block size of 64 bits (2 longs). I'll likely port it over to assembly the next time I'm bored to see how fast I can get it to run. I hope someone will find the object useful.
Paul Baker
  • deSilvadeSilva Posts: 2,967
    edited 2008-03-07 23:53
    We were compiling a list of benchmarks some weeks ago. I should suggest to add this to it.
    But where is that list???
  • RaymanRayman Posts: 16,460
    edited 2008-03-08 00:06
    Out of curiosity only...· Is this 64-bit encryption?· Do you have to worry about export control if you post 128-bit code?
    edited 2008-03-08 00:11
    It's 64 bit block size but the key size can be (theoretically) upto·72 bytes in length (572 bits) (however most references state max key length to be 448 bits or 56 bytes), I don't know what falls under export restrictions, whether it's the key size or the algorithm (I think it might be the latter).
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 3/8/2008 12:20:09 AM GMT
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-03-08 00:23
    Would it be possible to use more than one cog to speed it up? From what I have seen it looks like it would be hard to parrallelize (how do you like my new worksmile.gif )
    Paul,
    This is an excellent and interesting app for the Propeller. I'm wondering, though: does your impetus for understanding the algorithm have anything to do with code protection on the Prop II? wink.gif
    edited 2008-03-08 00:45
    @steven certain parts could be parallelized, the init function isn't a candidate since the next computed P-array and S-box values are self referential (each value is run through the encryption algorithm and therefore depends on the previously computed values and those values yet to be computed). The encrypt/decrypt work with a ladder network so it isn't really suitable for mutiprocessing either. However each encrypt and decrypt is independent of each other so multiple blocks can be worked on simultaneously.
    @Phil thanks, yes that was the impetus to looking into this stuff. I don't know if this algorithm will be used especially since the initialization process is so slow. Currently I'm envisioning a hub based Encryption block which can be aquired by a cog via a hardwired lock and will continue to own it until released (this is to protect the S-box and P array values from being accessed by other cogs). It would perform 1 encrypt/decrypt per hub access. Then upon release, all S-Box and P array values would be wiped before being availible to other cogs. This way the encryption algorithm can be used by user programs as well without compromising the security of the EEPROM code. This is all thought fodder, so it should not be infered that this is what will be done. I'll also be studying AES/Rijndael for computational speed comparisions, but I will also have to look at how exactly AES is restricted for foreign sale (and if it would be possible to step it down to 64bit to circumvent restrictions).
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 3/8/2008 12:54:46 AM GMT
    edited 2008-03-08 01:10
    This is really OT but would adding a memory protection scheme to the propeller help? Something like a table at the start of memory that only gives cogs access to certain areas of memory. Say group the memory into 512 long sections and each cog has a flag for access to that area of memory. Then you could just only allow the first cog access to the memory that contained the table and it could control memory access for all cogs or it could allow other cogs to set memory access as well. When a cog tried to read or write to memory that it wasn't it would just set the c flag maybe and do nothing (return 0 for read).
    Well maybe it is not OT. On the current propeller there is no way of protecting anything in the hub except by encrypting it (and this only prevents someone from reading it not modifying it). So if you want to do encryption than it has to be done completely in the cog (blowfish may fit, I don't know enough about it) or only allow trusted code to run. i.e. If you allowed loading of programs like DOL than you wouldn't be guaranteed protection.
  • Beanie2kBeanie2k Posts: 83
    edited 2008-03-08 02:00
    Export rules from the USA to other countries have been greatly relaxed in recent years (yes, occasionally we do something right smile.gif ). Today, for open source encryption algorithms (Blowfish and AES would qualify) I think it's just a matter of filling out some paperwork and giving the Feds a copy of the source code (for the paranoid: no, we are not required to give the government the keys or install a back door). I know the key length can be up to 256 bits, and I think it may be unlimited. You might want to check into this before posting any more code though, as I "think" (although I'm not sure) these restrictions also apply to code posted on the internet from a USA site.
    Possibly a greater concern would be the laws of other countries regarding the possession and use of strong encryption. It used to be that France did not allow the use of any encryption, and many other countries had quite strict rules as to what their population could and could not use. A lot of this may have changed in recent years also, especially with the formation of the EU and all the various and sundry trade agreements. Quite a minefield, it is.
    edited 2008-03-08 02:08
    France did not allow encryption? Than how could you use DVDs, a lot of micro-controllers, most operating systems, iTunes etc.
    All of these use encryption of one form or another. Were they not allowed?
  • tpw_mantpw_man Posts: 276
    edited 2008-03-08 02:49
    Good work. Now we need compression. smile.gif RLE would be fairly simple.
    I am 1010, so be surprised!
    edited 2008-03-08 04:25
    stevenmess2004 said...
    This was back in the days before DVD's and iTunes, circa 1991.· Like I mentioned, a lot has changed, but at that time it wasn't allowed, at least according to the source I had (I'll take a look tonight or tomorrow and see if I can find it).
    EDIT:· Here's a newer source.· It looks like they did change the law in France.
    http://en.wikipedia.org/wiki/Cryptography#Legal_issues_involving_cryptography
    Post Edited (Beanie2k) : 3/8/2008 5:25:33 AM GMT
  • OwenSOwenS Posts: 173
    edited 2008-03-08 10:35
    Paul,
    I'm not sure about it's relative security to other algorithms, but for a really small algorithm, look at XXTEA. Theres a reason TEA stands for Tiny Encryption Algorithm [noparse];)[/noparse]
    edited 2008-03-08 10:44
    I DO like that!!
    edited 2008-03-08 15:32
    It is also insecure as M$ found out the hard way.
    http://en.wikipedia.org/wiki/Tiny_Encryption_Algorithm
    edited 2008-03-08 15:51
    People can be most idiotic wrt hash functions..
    I once analysed a file system where they used
    SUM(fn[noparse][[/noparse] i ]) MOD 1024, where 'fn' contained the filename
    as a function to optimize the population of 1024 tables...
    This makes me still smile...
    edited 2008-03-08 15:52
    tpw_man said...
    yes, RLE is simple, but not· very efficient.
    Unless you only want to compress simple bitmaps, we really need some sort of Lempel-Ziv algorithm going. And no, they're not that difficult to implement.
    Don't visit my new website...
    edited 2008-03-08 20:43
    Beanie2k said...
    TEA is insecure. XTEA fixes those insecurities, though some have been found in it (Note that this is not yet a cryptographic break). XXTEA fixes the vunerabilities in XTEA, though an attack has been found for low round version (Less than 8 rounds).
    In any case, the TEA family is a lot smaller than Blowfish and AES, both in hardware and software.
    Note that XXTEA only requires adds, subtracts and fixed shifts, which can all be implemented easily in hardware, and one multiplication and division, which can be eliminated if a fixed number of rounds are used.
  • RinksCustomsRinksCustoms Posts: 531
    edited 2008-03-08 23:57
    In America, land of the free (so long as you can afford the leagle fees!) & home of the great (thieves - via copy-catting). In other words, In the eyes of a professional thief (the brief history of the PC is one good example), ANY security measure one employs only serves as a means of slowing down the aquisition of the desired "thing" (virtual or not). I believe the only way to truely protect your data/program is with a copywrite, but I fear that isn't even enough! Patents are good for a few decades, and other companies would bicker about you having a monopoly, and that it isn't fair that they can't make money copying your ideals.
    In any case, I think encryption is a bit of a waste of time. . .
    E3 = Thought
    http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
    edited 2008-03-09 06:57
    It will be interesting to see this from a historic point of view.
    You have to understand that through all known history and through all known civilizations, COMMUNICATION was the privilege of the king, the high priest, and the government. No one was ever allowed to distribute anything except the official versions, by threat of capital punishment (or cutting your tounge in more civilized communities)
    But even spreading the official news could be dangerious: "I know you are reading the gospels to the people, but I do not like the way you do it!"
    All regulations regarding mails, telephone, telegraphy, radio, tv, internet are structured according to the scheme that the governments grant exceptions to their most generic asset: To hold the truth and distribute it ad libitum. This has always been monitored by strict censorship, the prerequisite for it being the strict ommission of all ciphers.
    Very well known are the uses of "open ciphers" in literature.
    Persons using cipher were outlaws, subversives, or - indeed - business men.
    In some western countries the "age of enlightenment" started a slow change to this basic attitude; and the living at the "western frontier" was one of the efficient supporting forces. But it still took an immense struggle arround 1970 to make the shift - in some western countries!
    edited 2008-03-09 08:48
    Actually, ciphers were commonly used by the Romans when sending orders to military commanders and other high-ranking officials.
    The most common was a broomstick and a strip of cloth or paper.
    Wrap the strip around thee stick so that it makes a nice, tight spiral with no gaps or overlaps.
    Then write your message along the stick(you may rotate the characters so that they are aligned along the strip if you want). When you've written the message(you may write more than one line if you want to), unroll the strip, then write random characters in all the empty areas.
    To decode, just wrap the strip around a stick with the same diameter as the one used when coding it.
    It's even possible that they might have two messages on th same strip by using different size sticks.
    (The romans were good at delegating control, but they didn't always trust the ones they put in charge. What better way of giving orders to a trusted agent than to code it into 'official' orders to the flunky? This is a brainfart of my own, and there's no historical evidence that the Romans used this technique )
    edited 2008-03-09 10:48
    The SKYTALE was first mentioned 650 BC in Greece. This is simple to break and a main problem seemed to be to iron the paper tape, as it would otherwise keep some of the tension from the stick, which made it simple to judge the diameter which was the only encryption parameter. I personally think it was not considered safer than when we seal an envelope....
    It however might have been also used as an implicite authorization! Simple as it is to decipher, it is not so easy to guess what SKYTALE will be used for the receiver without much more espionage.
    And note that Gadgetman is talking about the Roman administration, not about the "Romans" smile.gif
    Post Edited (deSilva) : 3/9/2008 10:59:13 AM GMT
  • PaulFPaulF Posts: 62
    edited 2009-05-18 16:31
    Sorry to drag this one up from the past. But I am currently creating a largish file (up to 20Mb) on a pc that is to be read from an SD card via an SD card. The Propeller reads a block of characters (8 - 16) from the file in a sequential manner. No problem here.
    I would like to encrypt the file with a secure algorithm such as Blowfish etc. My knowledge of encryption is scant to say the least.
    Is it necessary to decrypt the complete file before reading the blocks of characters or is there a way to decrypt the characters 'on the fly' as they are needed. I have played with a simple XOR key which has given adequate results but I'm just concerned about the level of security.
    Does anyone know how I can reliably and securely achieve this?
    Paul
    "There are 10 types of people in the world. Those who understand binary and those who don't."
    edited 2009-05-18 16:49
    with the propeller there really is no point encrypting the contents of the sd card if they will have the eeprom available also. The problem is the key can be easily read off the eeprom and used to decrypt the file contents.
    now if you are looking to encrypt data and put it onto an sd card. otp is the most secure and simplest encryption method available. it requires hand delivery of a large encryption key though.
    My new unsecure propmod both 1x1 and full size arriving soon.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-05-18 17:35
    Thanks McTrivia,
    I understand what you are saying. Call me naive but what about these two 'possible' solutions:
    1) what if the prop had two SD cards. One to contain the file to be read and the second to contain a key to unlock the file on the other card. Ok if the 'criminals' got access to both files they could crack that file but not any subsequent files.
    2) If the key was held in a battery backed RAM (or SRAM/FRAM). How easy is it for the 'criminals' to read the contents of the Ram?
    edited 2009-05-18 17:45
    What kind of information are you trying to secure? If the criminal has knowledge of electronics and programing or knows someone that does then it would be easy to get the data from ram. I am assuming the device is not so big that it is not inconceivable that they would not just steal the entire thing.
    edited 2009-05-18 18:01
    Hi McTrivia,
    the data is of reasonably low value on a file by file basis. I would just rather that they do not get one key that will unlock all files. I cant say what the data is at this moment. Sorry!
    edited 2009-05-18 18:13
    was not asking for exact numbers.
    if the card is ment to be a permenent ficture inside the machine then you are better off to try and build in tamper protection devices to erase the card or at least the key.
    Some protection devices available to you:
    1) remove physical access to code. This is the idea behind my secure propmod. I built it so that you can program it then secure the code. to access the code after that would require carefull destruction of the module. possible but difficult to do without breaking the eeprom
    2) put key in non battery backed up ram. if power is lost even for a second key is gone. problem is lost also on inadvertent power loss.
    3) actively look for tampering then delete data when found. photo detectors inside a sealed box, capacitive sensors between to metal boxs, there are many ways to do this and many ways to get around each. the trick is to not let anyone know what you are using and use more then 1 system.
    4) Encrypt data. this only protects against people pooping the card out and reading. does little against someone with access to the hardware and knowledge.
    4 works but not very well. 4 combined with 1 or 2 would work very well. 3 is the best but requires careful planing and the most expensive to implement and still best to combine with 1 & 4.
    I mentioned my original propmod. http://www.propmodule.com/?x=products_propmod this has a built in uSD card reader. Implementing 1 & 4 with it would be easy as you can place the key in the eeprom and the data on the sd card.
    edited 2009-05-18 18:39
    Food for thought! I like these suggestions, particularly the sealed box approach! I will ponder over these and hopefully come up with a solution. BTW I have been reading (lurking some maight say) the posts relating to your propmod. I think it is a great idea and I hope it does well for you. Unfortunately because of other issues with my current project I can't use it but I will certainly consider it for future pojects.
    Keep up the good work and many thanks for your suggestions.
    Paul
    edited 2009-05-18 18:44
    Glad i could help.
    the original propmod is not doing to well. i have sold 4 and 2 of them to myself. Most people just aren't interested in code security. I have an order of 200pcb arriving on Tuesday and 35 props arriving Wednesday for my new unsecure modules and 1x1s. these look like they will probably do better. partially probably because they are so cheap.
  • hinvhinv Posts: 1,272
    edited 2009-05-20 02:26
    Hi Paul,
    Has there been any progress in putting this into assembly?
    Doug
