Need an object for a 16bit 4 channel A/D IC?
Has any one seen or developed an object for an ADS8341E data sheet here -> pdf1.alldatasheet.com/datasheet-pdf/view/83671/TI/ADS8341E.html
I am looking for any object that will work. It is a 4 channel 16 bit A/D IC. Please help I am still new at this so simple would be preferred.
Thanks.
Thanks.
www.ti.com/lit/gpn/ads8341
If you look at the timing chart on page 12-14 you will see that there is nothing magical or mystical about the interface, it's just a straight SPI'ish interface. Surely you could use one of the many similar objects and tweak it to suit. It's an achievable goal if you don't feel too confident and it will build your coding skills thereby boosting your confidence. No need then to depend on us cocky bit jockeys to change a couple of lines of code at our leisure when you can empower yourself in this regard.
Just follow the yellow brick road, step by step as you clock the data bits in and out then at the end click your heels and presto! there you are in Kansas. (Simplified version)
*Peter*
