Anyone have the parallax serial VFD working? (GU112X16G-7003)
I'm not quite sure what I'm doing wrong here, but I just get nothing or moving garbage on the display when I try to hook this display up. I got the display working with little trouble on the BS2 a while back using the provided demo code, but when I attempt to just port some basic stuff over to the prop it does not go well. First I tried adapting the Debug_LCD demo and that got me moving junk (Looks like it's trying but the wrong characters are coming out). Then writing a little test code using the basic serial driver and again I just seem to get what looks like cyrilic characters. But in this case the screen is filled with them so it does not seem to be mapping to the "Hello, World!" message I'm trying to send.
This is hooked up to a protoboard with 5v from the on board regulator and serial from pin 0. I'm pretty new to this stuff so I'm sorry if I end up waisting someones time, I'm sure I'm just making some sort of basic mistake.
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
LCD_PIN = 0 ' for Parallax 4x20 serial LCD on P0
LCD_BAUD = 19_200
LCD_LINES = 2
OBJ
serial : "Simple_Serial"
PUB main
if serial.start(-1, LCD_PIN, LCD_BAUD)
serial.str(string($1B, $40)) 'init string from appnote
waitcnt(clkfreq / 5 + cnt)
serial.str(string($1F, $28, $77, $10, $01)) 'apparently more initialization?
serial.str(string("Hello, World!"))
'' Parallax Serial VFD (Noritake GU112X16G-7003)Test '' '' '' '' '' CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz) VFD_PIN = 2 ' serial VFD on P5 VFD_BAUD = 38400 ' minumum baud for display OBJ serial : "FullDuplexSerial" PUB main if serial.start(1, VFD_PIN, 0, VFD_BAUD) serial.tx($1B) ' init display serial.tx($40) ' init display serial.str(string("Hello World!")) ' send "Hello World!"▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
