DS1302 Timekeeping Chip — Parallax Forums
Computer Geek 101Computer Geek 101 Posts: 179
edited 2008-03-11 12:00 in General Discussion
Im using the DS1302 Timekeeping Chip in a time clock.· I have a battery backup to keep the time when power is gone.· Sometimes the clock "locks up" and wont change until I send it the update time command.· Is there any way to keep the RTC from locking up on the time?
    edited 2008-03-07 18:13
    Computer Geek 101
    You may·have found what i found ·out that when the battery get low if you are
    using nicads the time will stop and all you have is the time where it stop
    That is why i post this in the completed Project forum
    http://forums.parallax.com/showthread.php?p=709460
    So i could run the Basic Stamp and the DS1302 chip on one· battery pack
    and not use the DS1302 battery Back·Up·Mode
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 3/7/2008 6:20:48 PM GMT
  • Computer Geek 101Computer Geek 101 Posts: 179
    I found the answer. even though it says the charge mode is disabled on startup, when I sent the proper commands to the chip the battery backup worked like its supposed to(I noticed I was getting 5v from the battery pin without a battery hooked up to it).
    SHIFTOUT 1, 0, LSBFIRST, [noparse][[/noparse]$90,$00]
