Division problem
I am taking two digital channels and counting the pulse length then dividing Sensor1 by Sensor2. Division isn't close when numerator is less than denominator. Any ideas as to what I am missing?
Two examples
Channel Test 1 Test 2
Sensor 1 14264 11152
Sensor 2 12461 12460
STAMP result 1.1441 0.3111
Real result 1.1446 0.89502
' {$STAMP BS2px}
' {$PBASIC 2.5}
Sensor1 PIN 4
Sensor2 PIN 7
S1 VAR Word
S2 VAR Word
TH VAR Word
r VAR Word
qI VAR Byte
qF VAR Word
i VAR Nib
DO
GOSUB Pulse_Test
GOSUB Cal_Ratio
GOSUB Display
LOOP
Pulse_Test:
PULSIN Sensor1,1,S1
PULSIN Sensor2,1,S2
RETURN
Cal_Ratio:
qI = S1 / S2
r = S1 // S2 ' Remainder
qF = 0 ' Clear fractional quotient
FOR i = 1 TO 4 ' Four digits to right of decimal
r = r * 10 ' Multiply remainder by 10
qF = (10 * qF) + (r / S2) ' Multiply quotient by 10 and add
r = r // S2 ' Calculate next remainder
NEXT
IF((r * 10 / S2) >= 5) THEN qF = qF + 1' 5th digit, round up if needed
RETURN
Display:
DEBUG CRSRXY, 0, 1
DEBUG "Sensor1..", DEC5 S1,CLREOL, CR
DEBUG "Sensor2...", DEC5 S2,CLREOL, CR
DEBUG "Cal Ratio...",DEC qI, ".", DEC4 qF, CLREOL, CR
RETURN
Two examples
' {$STAMP BS2px}
' {$PBASIC 2.5}
Sensor1 PIN 4
Sensor2 PIN 7
S1 VAR Word
S2 VAR Word
TH VAR Word
r VAR Word
qI VAR Byte
qF VAR Word
i VAR Nib
DO
GOSUB Pulse_Test
GOSUB Cal_Ratio
GOSUB Display
LOOP
Pulse_Test:
PULSIN Sensor1,1,S1
PULSIN Sensor2,1,S2
RETURN
Cal_Ratio:
qI = S1 / S2
NEXT
RETURN
Display:
DEBUG CRSRXY, 0, 1
RETURN
I suspect you will find the answer to your division question here:
http://www.emesystems.com/BS2math2.htm
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
Instead of decimal long division, use binary long division. It works for denominators up to 32768:
www.emesys.com/BS2math2.htm#binary_long
After the division, convert back to a decmal fraction using the operation, ** 10000.
Tracy Allen
www.emesystems.com
