Voltage Regulator Resistance
Hi all,
Though I don't currently have the part number on-hand regarding the specific Vreg I am questioning, the question is pretty general.
Should my 3.3V Voltage Regulator have a measurable resistance between Vout (3.3V) and Ground (0V)?
I have a Vreg (whose flag is at 3.3V, not ground (grumble! grumble!)) that, when measured, shows a value of ~570 Ohm between Vout and Ground. When I measure the 5V Vreg I use on my homebrew board, it shows infinite resistance (and it's flag is connected to ground!!!). I have a spare 3.3 Vreg, and it measures ~570 ohm also. I get a good 3.3V out of it, but I think the resistance is messing with my circuit.
I think it is fine, and this is common, but I'd love if if someone would confirm, for sanity's sake. Any other thoughts are welcome as well.
-Parsko
-Parsko
Bottom line: 1) Don't use an Ohmmeter to measure "resistance" at the output of a regulator. The value you measure is not very useful.
2) The apparent "resistance" at the output of a regulator is not a useful measure. What you're interested in is the maximum current available from the regulator (that will affect what you can draw from it), the voltage drop from input to output (that will affect what the input voltage has to be and the amount of power converted to heat), the thermal resistance of the packaging (that will affect how well the regulator can get rid of excess heat), and the transient response of the regulator to sudden changes in load (that will affect how much filtering will be needed to supply power transiently).
Post Edited (Mike Green) : 3/5/2008 9:34:11 PM GMT
Now the output resistance of a signal source does matter, especially at higher frequency signals and when there is·more than a few inches between the source and the load (transmission line effects).
Paul Baker
