Loading eeprom and/or ram errors..
Rontopia
hi guys.. I am having trouble loading a file in to the eeprom. when I try to load this code which is from one of the labs.. i think its the methods lab, I get this..
Cannot find source file: c:\Program Files\Parrallax Inc\Propeller\Propeller Tool v1.01.5\Examples\Labs\TextMessages.spin
the code is
''File: CogStartStopWithButtons
''Launches methods into cogs and stops the cogs within loop structures that
''are advanced by pushbuttons
VAR
······· long stack[noparse][[/noparse]60]
PUB ButtonBlinkTime | time, index, cog[noparse][[/noparse]6]
··· repeat
······· repeat index from 0 to 5
······· time := ButtonTime(23)
······· cog[noparse][[/noparse]index] := cognew(Blink(index + 4, time, 1_000_000), @stack[noparse][[/noparse]index * 10])
··· repeat index from 5 to 0
······· ButtonTime(23)
······· cogstop (cog[noparse][[/noparse]index])
PUB Blink(pin, rate, reps)
··· dira[noparse][[/noparse]pin]~~
··· outa[noparse][[/noparse]pin]~
··· repeat reps * 2
······· waitcnt(rate/2 + cnt)
······· !outa[noparse][[/noparse]pin]
PUB ButtonTime(pin) : delta | time1, time2
··· repeat until ina[noparse][[/noparse]pin] == 1
··· time1 := cnt
··· repeat until ina[noparse][[/noparse]pin] == 0
··· time2 := cnt
··· delta := time2 - time1
any light at all? to me it seems like I should have a TextMessages.spin File? what is that and where do I get it?
also when I load it in to the ram.. I get nothing. it looks like the program loaded but the program does not run even tho there seems to be no complile errors.
thanks
IC layout designer
Austin Texas
the code is
VAR
··· repeat
··· repeat reps * 2
··· time1 := cnt
··· time2 := cnt
thanks
IC layout designer
Austin Texas
I am 1010, so be surprised!
I would really like to understand this.
IC layout designer
Austin Texas
The error message sounds correct. Somehow the Propeller Tool thinks your source program should be in a particular place with a particular name and there's nothing there with that name.
I suggest you locate the file you want to use with the Windows File Explorer and double click on that file to force the Propeller Tool to start using that file, then use the file window on the left in the Propeller Tool to find the directory and the file that you want and re-open the file that way. This will force the Propeller Tool to start with a known good file, then reset its internal file information to match so that it will open with that file in the future (until you change it).
Just hit F10 to load to ram and F11 to load to eeprom. No need to bother with the top file stuff if you are running into problems when using it.
IC layout designer
Austin Texas
