PASD Fails to Start
Hello.
I've been using PASD and have become somewhat addicted to it.
Now the program tries to start, but crashes before opening fully.
Anyone else have this problem? Is there a·fix?
TIA
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
TIA
I have accidentally left an Expire Date ( 1. Mars 2008) in the source code. This was only intended for the early Beta-versions.
Now I have an updated version (0.3) on my website, that shoud work forever
Only the .exe has changed, so you only have to replace this. I also fixed the bug with F2.
Link:
www.insonix.ch/propeller/prop_pasd.html
Cheers
Andy
If you ever revisit it for feature additions for which I would happily donate ...
Please consider in order of importance:
1) Provide a "continue" function that allows running after a break;
2) Make the "on top" feature of RAM viewers optional;
3) Make the virtual LEDs resizable;
Another interesting idea is a .spin debugger ... I've considered writing one.
This is the single biggest missing feature in propeller today.
Cheers 8)
2) This is doable, but If they are not on top, you have to bring it on top after every single step, if needed. I found it easier to minimize and restore the viewer windows.
3) This can be done
Yes a Spin debugger would be great, but the problem is the assignement of the bytecode to the Spin source lines. For PASM this is relativly easy because every line produces a long in the Cog RAM (with some exeptions). Today we know much more about the bytecode (thanks hippy) then last year when I have made the PASD, so it may be possible... (I don't plan to make it).
Andy
My somewhat impatient nature got the best of me [noparse]:)[/noparse]
Thanks.
Agreed. The main obstacle as Andy notes is being able to relate the bytecode to source line and knowing where variables are in memory. The PropTool may one day produce a listing or cross-reference which would help there, and hopefully any third-party compilers will do that.
The other solution is to decompile the bytecode to Spin source code but that would by necessity be much more artificial and would require a fair bit of work.
