Parallax GPS sensor questions — Parallax Forums
kur1jkur1j Posts: 2
edited 2008-03-04 06:03 in Robotics
I am having some trouble with understanding how this GPS sensor is sending data.
What I am trying to accomplish here is to to be able to take the RAW data coming from the GPS sensor and parse the information and output it how I want it to.
For example this is how I am trying to get an array of a NMEA string:
if(condition == true)
printOutGpsInfo()
printOutGpsInfo()
gpsData = -1
while(GpsData != 13)· //carriage return; so this will run until a carriage return is seen
gpsData = Serial.read();·· //this gets a character from the GPS sensor
if(gpsData = empty){
wait(100ms)
else{
array[noparse][[/noparse]i++]=gpsData;· //store that character
Granted this is not actual code just my logic. So what I am expecting is·my array·to contain is·information such as
[noparse][[/noparse]code] $GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E*68
[noparse][[/noparse]/code]
but sometimes it is and sometimes it isn't. Sometimes two strings will be run together sometimes it will just cut off in the middle of the string. If I change the while(GpsData != 13) to while(1) and just watch the data on my serial output everything looks fine.
This is an example of while(GpsData != 13)
[noparse][[/noparse]code] ,N,00440.5161,W,0,00,,-00044.7,M,051.6,M,,*6B $GPGSA,A,1,,,,,,,,,,,,,,,*1E $GPGSV,3,1,10,02$G154655,4328.1874,N,00340.5185,W,1,03,08.5,-0$GPGSA,A,2,13,23,25,,,,,,,,,,08.5,08.5,00.9*0E $GPGSV,3,1,10,02,50,290,26,04,60,210,26,08,33,173,29,10,21,296,00*7E $GPGSV,3,2,10,13,58,044,34,16,03,035,00,20,02,109,00,23,26,057,34*7B $GPGSV,3,3,10,,,,,,,,,*7D $GPRMC,154655,A,4428.,,,,,,,,,,,W,000.7,000.0,050407,,,A*6C [noparse][[/noparse]/code]it is totally random as well I can't figure out what its actually doing when this is happening. If I run while(1) and watch the data it is correct 100% of the time.But the problem is I can't do anything with this. I cant stay in this loop forever
Overall in words this is what I am wanting...
When I call printOutGpsInfo() I want my array to have each character in an element in the array.
[noparse][[/noparse]code]$GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E*68[noparse][[/noparse]/code]
I am really close to figuring this out and just need a little push in the right direction on what this actual GPS sensor is doing.
Edit: I know the GPS sensor works as I found some example code that works correctly but the GPS sensor has to constantly execute that code. You can look at it here.
http://www.arduino.cc/playground/Tutorials/GPS
GPS module: http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/GPS/List/1/ProductID/396/Default.aspx?SortField=ProductName%2cProductName
  • kur1jkur1j Posts: 2
    Got it working exactly how I wanted it to.
    Here is the code if anyone wants it.
    #include <string.h>
    #include <stdio.h>
    #include <ctype.h>
    #include <SoftwareSerial.h>
    #define btrxPin 2
    #define bttxPin 3
    ·int RFID = 0;
    ·int RFIDPin = 14;
    ·int rxPin = 0;··················· // RX PIN
    ·int txPin = 1;··················· // TX TX
    ·int temp = 0;
    ·int byteGPS=-1;
    ·char linea[noparse][[/noparse]300] = "";
    ·char readLine[noparse][[/noparse]200] = "";
    ·char comandoGPR[noparse][[/noparse]7] = "$GPRMC";
    ·int cont=0;
    ·int bien=0;
    ·int conta=0;
    ·int indices[noparse][[/noparse]13];
    SoftwareSerial BTSerial = SoftwareSerial(btrxPin, bttxPin);
    ·void setup() {
    ·· pinMode(btrxPin, INPUT);
    ·· pinMode(bttxPin, OUTPUT);
    ·· pinMode(RFIDPin, INPUT);
    ·· Serial.begin(4800);
    ·· BTSerial.begin(9600);
    ·· for (int i=0;i<300;i++){······ // Initialize a buffer for received data
    ···· linea[noparse][[/noparse]i]=' ';
    · for(int i = 0; i<200; i++)
    ····· readLine[noparse][[/noparse]i]=' ';
    void loop()
    ·· RFID = digitalRead(RFIDPin);
    ·· if(RFID == HIGH)
    ···· BTSerial.println("Check the below location:");
    ···· BTSerial.println("");
    ···· //Serial.println("Check the below location:");
    ···· getGPRMC();
    void getGPRMC()
    · temp = 0;
    · int byteGPS;
    · byteGPS = -1;
    · int indices[noparse][[/noparse]13];
    · int commaPlace[noparse][[/noparse]13];
    · int count = 0;
    · int cout = 0;
    · int flag = 0;
    · for(int i = 0; i < 13; i++)
    ···· commaPlace[noparse][[/noparse]i] = ' ';
    ·· Serial.flush();
    ·· while(byteGPS != 13 || readLine[noparse][[/noparse]0] != '$' || readLine[noparse][[/noparse]1] != 'G' || readLine[noparse][[/noparse]2] != 'P' || readLine[noparse][[/noparse]3] != 'R' || readLine[noparse][[/noparse]4] != 'M' || readLine[noparse][[/noparse]5] != 'C')
    ····· byteGPS = Serial.read();
    ····· if(byteGPS == -1)
    ········ delay(100);
    ····· else
    ······· //printByte(byteGPS);
    ······· if(byteGPS == '$')
    ········· temp = 0;
    ········· readLine[noparse][[/noparse]temp++] = byteGPS;·······
    ······· else
    ··· Serial.println("");
    ··· for(int i = 0; i<temp; i++)
    ····· Serial.print(readLine[noparse][[/noparse]i]);
    ······ if(readLine[noparse][[/noparse]i] == ',')
    ········ commaPlace[noparse][[/noparse]count++] = i;
    ······ else if(readLine[noparse][[/noparse]i] == '*')
    ········ commaPlace[noparse][[/noparse]12] = i;
    ··· for(int i = 0; i< 13; i++)
    ····· Serial.println(commaPlace[noparse][[/noparse]i]);
    ··· for(int i = 0; i < temp; i++)
    ······ flag++;
    ····· if(flag == 1)
    ······· Serial.print("Time in UTC (HhMmSs): ");
    ······· BTSerial.print("Time in UTC (HhMmSs): ");
    ······· flag++;
    ····· else if(flag == 2)
    ········ Serial.print(readLine[noparse][[/noparse]i]);
    ········ BTSerial.print(readLine[noparse][[/noparse]i]);·
    ····· if(flag == 3)
    ······· Serial.println("");
    ······· Serial.print("Status (A=OK, V=KO): ");
    ······· BTSerial.println("");
    ······· BTSerial.print("Status (A=OK, V=KO): ");
    ······· flag++;
    ···· else if(flag == 4)
    ····· if(flag == 5)
    ······· Serial.print("Latitude: ");
    ······· BTSerial.print("Latitude: ");
    ······· flag++;
    ···· else if(flag == 6)
    ···· if(flag == 7)
    ······· Serial.print("Direction (N/S): ");
    ······· BTSerial.print("Direction (N/S): ");
    ······· flag++;
    ···· else if(flag == 8)
    ···· if(flag == 9)
    ······· Serial.print("Logitude: ");
    ······· BTSerial.print("Logitude: ");
    ······· flag++;
    ···· else if(flag == 10)
    ···· if(flag == 11)
    ······· Serial.print("Direction (E/W): ");
    ······· BTSerial.print("Direction (E/W): ");
    ······· flag++;
    ···· else if(flag == 12)
    ···· if(flag == 13)
    ······· Serial.print("Velocity in knots: ");
    ······· BTSerial.print("Velocity in knots: ");
    ······· flag++;
    ···· else if(flag == 14)
    ···· if(flag == 15)
    ······· Serial.print("Heading in degrees: ");
    ······· BTSerial.print("Heading in degrees: ");
    ······· flag++;
    ···· else if(flag == 16)
    ···· if(flag == 17)
    ······· Serial.print("Date UTC (DdMmYy): ");
    ······· BTSerial.print("Date UTC (DdMmYy): ");
    ······· flag++;
    ···· else if(flag == 18)
    ······· BTSerial.print(readLine[noparse][[/noparse]i]);········
    ···· if(flag == 19)
    ······· Serial.print("Magnetic degrees: ");
    ······· flag++;
    ···· else if(flag == 20)
    ···· if(flag == 21)
    ······· Serial.print("(E/W) ");
    ······· flag++;
    ···· else if(flag == 22)
    ···· if(flag == 23)
    ······· Serial.print("Mode: ");
    ······· flag++;
    ···· else if(flag == 24)
    /*·· for (int i=0;i<temp+1;i++){
    ···· if (readLine[noparse][[/noparse]i]==','){··· // check for the position of the· "," separator
    ······ indices[noparse][[/noparse]cont]=i;
    ······ cont++;
    ···· if (readLine[noparse][[/noparse]i]=='*'){··· // ... and the "*"
    ······ indices[noparse][[/noparse]12]=i;
    ······ cont++;
    ········ Serial.println("");····· // ... and write to the serial port
    ········ for (int i=0;i<12;i++){
    ·········· switch(i){
    ············ case 0 :Serial.print("Time in UTC (HhMmSs): ");break;
    ············ case 1 :Serial.print("Status (A=OK,V=KO): ");break;
    ············ case 2 :Serial.print("Latitude: ");break;
    ············ case 3 :Serial.print("Direction (N/S): ");break;
    ············ case 4 :Serial.print("Longitude: ");break;
    ············ case 5 :Serial.print("Direction (E/W): ");break;
    ············ case 6 :Serial.print("Velocity in knots: ");break;
    ············ case 7 :Serial.print("Heading in degrees: ");break;
    ············ case 8 :Serial.print("Date UTC (DdMmAa): ");break;
    ············ case 9 :Serial.print("Magnetic degrees: ");break;
    ············ case 10 :Serial.print("(E/W): ");break;
    ············ case 11 :Serial.print("Mode: ");break;
    ············ case 12 :Serial.print("Checksum: ");break;
    ·········· for (int j=indices[noparse][[/noparse]i];j<(indices[noparse][[/noparse]i+1]-1);j++){
    ············ Serial.print(readLine[noparse][[/noparse]j+1]);
    ·· //while to the end...(byte13)
    ·· // Serial.println("");
    ··· for(int i = 0; i<200; i++)
    ····· readLine[noparse][[/noparse]i] = ' ';
    · delay(1500);
    void GPS()
    ·· byteGPS=Serial.read();········ // Read a byte of the serial port
    ·· if (byteGPS == -1) {·········· // See if the port is empty yet
    ···· delay(100);
    ·· } else {
    ···· linea[noparse][[/noparse]conta]=byteGPS;······· // If there is serial port data, it is put in the buffer
    ···· conta++;·····················
    ···· printByte(byteGPS);
    ···· if (byteGPS==13){··········· // If the received byte is = to 13, end of transmission
    ······ cont=0;
    ······ bien=0;
    ······ for (int i=1;i<7;i++){···· // Verifies if the received command starts with $GPR
    ········ if (linea[noparse][[/noparse]i]==comandoGPR[noparse][[/noparse]i-1]){
    ·········· bien++;
    ······ if(bien==6){·············· // If yes, continue and process the data
    ········ for (int i=0;i<300;i++){
    ·········· if (linea[noparse][[/noparse]i]==','){··· // check for the position of the· "," separator
    ············ indices[noparse][[/noparse]cont]=i;
    ············ cont++;
    ·········· if (linea[noparse][[/noparse]i]=='*'){··· // ... and the "*"
    ············ indices[noparse][[/noparse]12]=i;
    ········ BTSerial.println("");····· // ... and write to the serial port
    ············ case 0 :BTSerial.print("Time in UTC (HhMmSs): ");break;
    ············ case 1 :BTSerial.print("Status (A=OK,V=KO): ");break;
    ············ case 2 :BTSerial.print("Latitude: ");break;
    ············ case 3 :BTSerial.print("Direction (N/S): ");break;
    ············ case 4 :BTSerial.print("Longitude: ");break;
    ············ case 5 :BTSerial.print("Direction (E/W): ");break;
    ············ case 6 :BTSerial.print("Velocity in knots: ");break;
    ············ case 7 :BTSerial.print("Heading in degrees: ");break;
    ············ case 8 :BTSerial.print("Date UTC (DdMmAa): ");break;
    ············ case 9 :BTSerial.print("Magnetic degrees: ");break;
    ············ case 10 :BTSerial.print("(E/W): ");break;
    ············ case 11 :BTSerial.print("Mode: ");break;
    ············ case 12 :BTSerial.print("Checksum: ");break;
    ············ BTSerial.print(linea[noparse][[/noparse]j+1]);
    ·········· BTSerial.println("");
    ······ conta=0;··················· // Reset the buffer
    ······ for (int i=0;i<300;i++){··· //·
    ········ linea[noparse][[/noparse]i]=' ';············
