Serial Communication - Too Slow??
I have a relatively sophisticated setup with a BS2e and an Arduino (ATmega168). The BS2e is communicating to a hacked Roomba, while receiving data from the Arduino regarding servo position, and readings from an IR sensor, and then making decisions based on the data. The robot that I have put together with this setup, so far, is extremely (mentally) slow. The BS2e can't catch up, it seems, to obtain the servo and IR sensor data, fast enough so that it get get the full resolution of the revolutions of the servo (yes, you may need to read that again), and every IR reading between one pule of the servo (this is a standard hobby servo). So, the data that the BS2e sees is a little 'late', meaning that data was from a couple milliseconds ago, and that's too slow. So, if there's an object really far in front of the IR sensor, then the robot will see it and turn, but if it's too close, then it will trigger the bumper switch on the Roomba. The robot will then act a few milliseconds later, but not fast enough so that right when the bumper touches the wall/plany/etc., it turns away; even then it will still be pushing against the object for a reasonable amount of time. The reason why I have a BS2e and an Arduino together is for ease of use. The Arduino has an A/D converter, and can do tasks that the BS2e can't, and the BS2e has features that the Arduino can't muster. So I thought I'd combine them; it's easier. But how can I speed this robot up? I know Parallax does not support the Arduino, but maybe someone that knows about C code can help? I mean, all these programming languages have SOMETHING in common. Below is the BS2e code.
And here's the Arduino code:
Giggly Googley!
Post Edited (NoBo780) : 3/3/2008 3:15:31 AM GMT
' {$STAMP BS2e} ' {$PBASIC 2.5} DD PIN 13 ' blue RXD PIN 14 ' orange TXD PIN 15 ' green LED PIN 8 LSRB PIN 2 LSRF PIN 1 INPUT TXD ARX PIN 1 ' data in from Arduino BAUDFAST CON 32 ' 19,200 bps BAUDMED CON 84 ' 9,600 bps BAUDSLOW CON 396 ' 2,400 bps R_START CON 128 R_BAUD CON 129 R_CONTROL CON 130 R_FULL CON 132 R_POWER CON 133 R_SPOT CON 134 R_CLEAN CON 135 R_DRIVE CON 137 R_MOTORS CON 138 R_SONG CON 140 R_PLAY CON 141 R_SENSORS CON 142 SENS_BUMPWHEEL VAR Byte SENS_WALL VAR Bit SENS_CLIFF_L VAR Bit SENS_CLIFF_FL VAR Bit SENS_CLIFF_FR VAR Bit SENS_CLIFF_R VAR Bit SENS_VWALL VAR Bit SENS_MOTOROVER VAR Byte SENS_DIRT_L VAR Byte SENS_DIRT_R VAR Byte i VAR Byte BUMP_RIGHT VAR SENS_BUMPWHEEL.BIT0 BUMP_LEFT VAR SENS_BUMPWHEEL.BIT1 WHEELDROP_C VAR SENS_BUMPWHEEL.BIT4 WHEELDROP_L VAR SENS_BUMPWHEEL.BIT3 WHEELDROP_R VAR SENS_BUMPWHEEL.BIT2 MOTOROVER_L VAR SENS_MOTOROVER.BIT4 MOTOROVER_R VAR SENS_MOTOROVER.BIT3 IRVAL VAR Byte(3) PULSES VAR Word LOW DD PAUSE 100 HIGH DD PAUSE 2000 FOR i = 1 TO 3 LOW DD LOW LED PAUSE 250 HIGH DD HIGH LED PAUSE 250 NEXT SEROUT RXD, BAUDFAST, [noparse][[/noparse]R_START] PAUSE 100 SEROUT RXD, BAUDFAST, [noparse][[/noparse]R_BAUD, 3] ' 3 == 2400 bps PAUSE 100 SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_START] PAUSE 100 SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_CONTROL] PAUSE 100 Main: DEBUG "at the top", CR GOSUB Update_Sensors IF BUMP_RIGHT THEN GOSUB Spin_Left PAUSE 1000 ELSEIF BUMP_LEFT THEN GOSUB Spin_Right PAUSE 1000 ENDIF GOSUB Go_Forward PAUSE 100 GOTO Main Update_Sensors: DEBUG "update sensors",CR SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_SENSORS, 1] SERIN TXD, BAUDSLOW, 2000, No_Data, [noparse][[/noparse]SENS_BUMPWHEEL,SENS_WALL, SENS_CLIFF_L,SENS_CLIFF_FL,SENS_CLIFF_FR,SENS_CLIFF_R, SENS_VWALL,SENS_MOTOROVER,SENS_DIRT_L,SENS_DIRT_R] Read_IR: DEBUG "reading IR",CR SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("PULSE"),DEC4 PULSES] IF PULSES > 1300 AND PULSES < 1500 THEN SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("IR"),DEC4 IRVAL] IF IRVAL > 200 THEN GOSUB Spin_Right ENDIF ELSEIF PULSES > 1500 AND PULSES < 1700 THEN SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("IR"),DEC4 IRVAL] IF IRVAL > 200 THEN GOSUB Spin_Right ENDIF ELSEIF PULSES > 1700 AND PULSES < 1900 THEN SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("IR"),DEC4 IRVAL] IF IRVAL > 200 THEN ' detected middle GOSUB Spin_Right ENDIF ELSEIF PULSES > 1900 AND PULSES < 2100 THEN SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("IR"),DEC4 IRVAL] IF IRVAL > 200 THEN GOSUB Spin_Left ENDIF ELSEIF PULSES > 2100 AND PULSES < 2300 THEN SERIN ARX,BAUDMED,[noparse][[/noparse]WAIT("IR"),DEC4 IRVAL] IF IRVAL > 200 THEN GOSUB Spin_Left ENDIF ENDIF DEBUG "pulses",CR DEBUG DEC4 PULSES DEBUG "ir",CR DEBUG DEC4 IRVAL RETURN No_Data: DEBUG "no data!",CR RETURN Done: PAUSE 1000 SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_POWER] ' turn off STOP Spin_Left: SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_DRIVE,$00,$c8,$00,$01] RETURN Spin_Right: FOR i = 1 TO 10 SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_DRIVE,$00,$c8,$ff,$ff] NEXT RETURN Go_Forward: SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_DRIVE,$00,$c8,$80,$00] RETURN Go_Stop: SEROUT RXD, BAUDSLOW, [noparse][[/noparse]R_DRIVE,$00,$00,$00,$00] RETURN
int servoPin = 3; int irPin = 0; int val = 0; int pulses; void setup() { Serial.begin(9600); pinMode(servoPin, OUTPUT); } void loop() { if(pulses >= 2300) { pulses = 2300; do { pulses = pulses - 50; digitalWrite(servoPin, HIGH); delayMicroseconds(pulses); digitalWrite(servoPin, LOW); delay(20); readir(); } while(pulses >= 1300); } else if(pulses <= 1300) { pulses = 1300; do { pulses = pulses + 50; digitalWrite(servoPin, HIGH); delayMicroseconds(pulses); digitalWrite(servoPin, LOW); delay(20); readir(); } while(pulses <= 2300); } } void readir() { val = analogRead(irPin); //delay(5); Serial.println("PULSE"); delay(5); Serial.println(pulses); delay(5); Serial.println("IR"); delay(5); Serial.println(val); }
Giggly Googley!
Giggly Googley!
I really think you need to use a Propeller. It can do the servo(s), ADC, and multiple serial interfaces and have plenty of processing power for the actual work of navigation.
Giggly Googley!
