The 0831 is no problem, it is the ad592. When powering the ad592 with 5 v to the red lead and running the ground pin to the in put of the 0831 I get a reading of 211 at 40 deg. and 216 a 70 deg. It works, but these are not usable figures.
There must be a way to set this up to get a wider range to enable some sort of accuracy.
This should provide you with the applications information you will need for the AD592 temperature probe, and its interface with the PBASIC Stamp: http://www.emesystems.com/OL2heat.htm#AD590
The EME Systems web site is full of all sorts of applications information, Stamp tips, methods of using precision math, and an assortment of other very worthwhile information. It's run by Dr. Tracy Allen, who is a regular on the Stamp Forum. I suspect he'll chime in if any problems develop with further concerns about accuracy.
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
What kind of documentation are you seeking?
Bruce Bates
Something that shows the diagram for attachement to an 0831 and how to callibrate.
Lou
Shouldn't most or all of that be in the AD592 temp probe documentation? We can certainly help with the wiring from the ADC to any PBASIC Stamp.
If you need something else, or anything additional that we can supply, just let us know.
Bruce Bates
Lou
Bruce Bates
Lou
