Do Until I get some new value
What is a good technique to accept a value through the serial port, take some action, and continue with that action until I get some new value through the serial port?
Here's my scenario:
Each mouse click in a seprate program sends a value to the BS2
Without the DO Until x<>Y (or Do While x=Y) the I only get one program loop.· With the Do statements, the program "latches" onto the first command and never stops.
Other than a degree in computer science, what am I missing?
THANKS
DO
··· 'accept decimal value in through serial port 16 at 2400,N,8,1
··· SERIN 16, 16780, [noparse][[/noparse]DEC y]
·············· x = y
·· DO UNTIL x <> y
········· IF x = 1 THEN
········· GOSUB Straight
········· ELSEIF x = 2 THEN
········· GOSUB TurnRight
········· ELSEIF x = 3 THEN
········· GOSUB BackUp
········· ELSEIF x = 4 THEN
········· GOSUB TurnLeft
········· ELSE
········· GOSUB Halt
········· ENDIF
········· GOSUB ApplyPulse
·· LOOP
LOOP
Here's my scenario:
THANKS
DO
·· DO UNTIL x <> y
········· ELSE
········· ENDIF
·· LOOP
LOOP
DO
SERIN RX,baud,30,Time_out,[noparse][[/noparse]DEC y]
conditional logic
LOOP
Jeff T.
As an alternative to Jeff's method (and with some added coding), here is another method you can try. Currently you have the following in your program:
DO
··· X = Y
· DO UNTIL X <> Y
· LOOP
LOOP
Have the other program send a leading character, such as "!". Then have the SERIN and the additional code look like this:
DO····················· 'Infinite loop
··· SERIN 16, 16780, [noparse][[/noparse]WAIT ("!"), DEC y]
··· X = Y·············· 'Save last Y
SELECT X············ 'Field value
·CASE = 1··········· 'Check value
·GOSUB Straight
·CASE = 2··········· 'Check value
·GOSUB TurnRight
·CASE = 3··········· 'Check value
·GOSUB BackUp
·CASE = 4··········· 'Check value
·GOSUB TurnLeft
·CASE ELSE
·GOSUB Halt
·ENDSELECT
'Select termination Point
LOOP
Just make sure at the top of your program you have included this:
' {PBASIC 2.5}
I find it quite a bit "cleaner" with SELECT...CASE, but do what makes you feel comfortable.
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
Post Edited (Bruce Bates) : 3/2/2008 6:22:08 AM GMT
Thank You verymuch for your response, but I'm not getting it. I tried it but nothing works.
My understanding is that the "WAIT" for a ! instruction will cause the stamp program to hold at that line until the stamp gets a ! character. If I only send a ! with each mouse click, won't the program hang?
I might be asking the stamp to do the impossible...I want to send the stamp a value of 1, 2, 3, 4 or 5 by clicking the mouse in a VB program.
I want the stamp to take the value sent to it, and execute the corresponding subroutine, and to continue with that executing that subroutine until some other value is sent. As I "talk" this out I need the stamp routine to periodically go back and check if any new data has come in the serial line. Two questions come up in my mind:
When I'm not clicking the mouse button is a 0 or NULL value being transmitted to the stamp?
If data is sent to the stamp when it's not "looking" will the data be lost?
Thanks again for everyone's input!
Below is the code:
VB Code:
Private Sub DataSendButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles DataSendButton.Click
Dim send As Integer = Val(TextDataToStamp.Text)
If _port.IsOpen Then
_port.WriteLine("!" & vbLf & send)
End If
End Sub
BSCode
[noparse][[/noparse] Title ]
'{$STAMP BS2}
'{$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
LeftServo PIN 13 ' Left Servo
RightServo PIN 12 ' Right Servo
[noparse][[/noparse] Variables]
x VAR Word
y VAR Word
PulseLeft VAR Word
PulseRight VAR Word
[noparse][[/noparse] Constants ]
pulse CON 15
[noparse][[/noparse] Initialization ]
[noparse][[/noparse] Main Routine ]
DO 'Infinite loop
X = Y 'Save last Y
SELECT X 'Field value
CASE = 1 'Check value
GOSUB Straight
CASE = 2 'Check value
GOSUB TurnRight
CASE = 3 'Check value
GOSUB BackUp
CASE = 4 'Check value
GOSUB TurnLeft
CASE ELSE
GOSUB Halt
ENDSELECT
GOSUB ApplyPulse
LOOP
'+++++++++++SubRoutines+++++++++++++++
timeout:
PAUSE 30
RETURN
ApplyPulse:
PULSOUT LeftServo,pulseLeft
PULSOUT RightServo,pulseRight
PAUSE pulse ' Constant defined above
RETURN
Straight:
pulseLeft = 850
pulseRight = 650
RETURN
TurnRight:
pulseLeft = 850
pulseRight = 850
RETURN
TurnLeft:
pulseLeft = 650
pulseRight = 650
RETURN
BackUp:
pulseLeft = 650
pulseRight = 850
RETURN
Halt:
pulseLeft = 750
pulseRight = 750
RETURN
There is a chance the SERIN will miss an input change or that it will read it incorrectly, so the mouse click might have to try again. It is a workaround. The Stamp does not have a serial buffer to store up incoming asynchronous data. It will only receive while it is sitting at and executing the SERIN command, and the SERIN timeout becomes part of the 20 or 30 millisecond loop that refreshes the servos.
Tracy Allen
www.emesystems.com
