How can I tell if a servo's busted?
For some reason one of my continuous rotation servos isn't moving at all. I inspected the wires and there's a small portion of the signal wire that looks like the wire tubing has been melted with a soldering iron.
I have been subjecting the servos to quickly-changing pulses (using a radio control system to move them), but my two other servos are fine.
I am powering the servo controller with a 4.8V 250 mAH battery through the breadboard, protected by two 6V rated 10mF capacitors.
It stopped working today. It is relatively new (purchased a few weeks ago). I am certain that the code is correct, because I wrote a very simple program just to see if it'd move at all.
What causes a servo to stop working? My project is on an urgent timeline and I need to know whether its wise to start ordering a new one right away. Is the "melted" wire a sure sign it's broken?
1. Since you've had it, has it been ran before.
2. If yes. When you ran it, did you do a torque test (ran the servo while holding the servo arm in one place). Common thing to do when you get a servo the first time.
3. If yes again. Did you hear snapping.
4. if yes to all question, your servo gears are worn.
If no at 2, then your wires are touching at the burnt·area or you have a bad servo chip (in the bottom of the servo), so you may have to get a new one. Sorry for the limited help. I need to see to say what it is. I have had years of hobby work though.
HMMMMMMMMMMMMMMMM.
Did it have an "unhappy" meating w/ a soldering iron and for how long?
Because it may have joined the vcc w/ the data wire or vice versa w/ the gnd wire, therefore disabling any chance for a signal to get to the servo. Not to mention possibly damaging the BS with the shorting of the power sources w/ the I/O pin.
I'm not exactly sure if it was the soldering iron that did the melting. I don't recall specifically any incident of touching the wires accidently, but it's possible I didn't notice. A nearby wire connecting the servo controller to the BS2 is also slightly melted, so perhaps it was a soldering iron.
If it is the case, is the servo now defunct?
P.S. try using the servo controller program they suggest to test the board and the servo at the same time. They have good documentation on that though.
the plastic on their own?
Have you checked the battery, presuming this is battery powered?
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
The melted wire does not look severe, and the "melted part" is only visible on the white part. Maybe I should snip that part off and splice a working connector.
Post Edited (skatj) : 3/2/2008 3:35:54 AM GMT
