Trying to find a componant from Toshiba.
Hi All,
I've got a gizmo that has a busted positioning sensor. The manufacturer won't provide just the sensor and wants to charge me over $600 for the whole modular assembly. So I'm trying to find the part myself. Hope someone can help.
It's a Toshiba part, but I can't locate the product number on their website. It is a photodiode gap sensor. Part number P1003A with 3C: on the second line.
Anyone have a suggestion where I can find this?
Lance
Lance
First, there is probably a reason why they want $600.00 for the whole assembly. Second, the numbers you have there are most probably a batch number or date code, rather than a legitimate part number. Third, if you can't find a part number, in a parts manual, parts schematic, or from a dealer, the chances are slim to none, of finding it just by what you presently have on the Internet.
Sorry!
Bruce Bates
"Genius is one percent inspiration and ninety-nine percent perspiration."
Thomas Alva Edison
Thanks, I hadn't thought about lot numbers, but ya that makes sense. There are other sensors on the unit that are the same and their numbers are different.
Guess I've got a lot of hours going through Toshiba's web site. Their tech documents aren't organized very well.
The gizmo is an HPLC autosampler. The unit cost is $16K new. But all scientific instrumentation companies that I'm familiar with treat the service department as a profit center. When the problem is a $5 part and they say I need to spend 120 times that when all I need to do is be handy with a soldering iron I get a little upset. I started my own company (ok, that's a little grand since it's just me and one part time engineer) to fix these things for a fraction of the fee the original company charges.
Thanks again. Wish me luck
Lance
I may have a lead on your autosampler unit. I need to know whether is is for gas or liquid samples? Once I get that far, I may be able to dig up a parts list with OEM part numbers. Let's hope!
Bruce Bates
Thomas Alva Edison
Forget my last question. Suppose I told you that the number on the device was "TLP1033A" instead of "P1003A"? Even if that's not the case, the "TL" may be a Toshiba prefix.
In any case, please take a look at page 13 of the attached PDF, and see if that's the beast you're seeking. If so, I'll send you a bill at the end of the month :-)
Bruce Bates
Thomas Alva Edison
Where did you find the PDF catalog?
And to answer your question, it is for liquid samples.
Lance
I'll let you in on a little secret. I was searching the Internet when Al Gore (sham inventor of the Internet) was wearing knickers. It's really no big deal, once you get the hang of it.
I had no idea what the piece of equipment was. So, I searched for "HPLC Autosampler". From that I ascertained what the device was, and that device was made by "HTA" in Italy. That led me nowhere.
So, then I said - suppose the part number is damaged on the part, or it was blurred somehow. Then I set out to search for "Toshiba photodiode gap sensor". That was the lead to the PDF that I eventually uploaded. "Eagle eye" noticed a similarity between "TLP1003A" and "P1003A' in a search description, and as they say the rest was history.
BTW - This was all done using Yahoo search, and took about 2 minutes flat. I also only have a dial-up connection.
Just don't be letting this secret out to anyone else on the forum
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
