7 segment display problems
hi my name is craig and i bought a kit to learn Pbasic code it came with a BS2 IC
in the book that comes with it there is a 7 segment display activity driving the 7 segment display to run from 0 - 9
Ok I have typed the code from the learning book EXACTLY AND SEVERAL times.
When I run the program it will just flash the first instruction infinitely but when I shorten the code to only 1-3 out puts on at a time it will work fine.
I’m confused if I'm doing something wrong or is my program IC bad.
Here is the code from the book
‘{STAMP BS2}
‘{PBASIC 2.5}
DEBUG “Program running.”
OUTH = %00000000
DIRH = %11111111
‘·············· BAFG.CDE
OUTH = %11100111
PAUSE 1000
OUTH = % 10000100
PAUSE 1000
OUTH = %11010011
PAUSE 1000
DITH = % 00000000
END
Here is the code that I can get to work but only 3 outputs at a time
‘{STAMP BS2}
‘{PBASIC 2.5}
OUTH = %00000000
DIRH = %11111111
OUTH = %11100000
PAUSE 1000
OUTH = % 11000100
PAUSE 1000
OUTH = %11010000
PAUSE 1000
DITH = % 00000000
END
The circuit is set up so I have a 1K ohm resistor in series with one input to seven segment and vss is my ground
Any input would be greatly appreciated
Thank you
Craig
‘{STAMP BS2}
‘{PBASIC 2.5}
OUTH = %00000000
DIRH = %11111111
OUTH = %11100111
PAUSE 1000
OUTH = % 10000100
PAUSE 1000
OUTH = %11010011
PAUSE 1000
DITH = % 00000000
END
‘{STAMP BS2}
‘{PBASIC 2.5}
OUTH = %00000000
DIRH = %11111111
OUTH = %11100000
PAUSE 1000
OUTH = % 11000100
PAUSE 1000
OUTH = %11010000
PAUSE 1000
DITH = % 00000000
END
Thank you
Craig
What's a Microcontroller book is·this one that you are using
It a lot·better if you go to http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Wamv2_2.pdf·and copy and
paste·the example Demo Code into the Basic Stamp Editor·Saying that
Make sure·you have hook up the 7- Segment LED Display right way·did you use the· Figure 6-10 for your hook up
Did you get the 7- Segment LED Display· from Parallax or did you get it from some where else
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/1/2008 1:32:48 AM GMT
i have got the same results
but when i changed my power supply to a 9v battery it works fine
i think my power supply dose not provide enough current
thanks again
