Displaying accelerometer readings
I am working in chapter 3: Tilt with the Memsic Accelerometer from the Smart Sensors and Applications SIC course.· Activity 4 has me scaling my readings and displaying the results to the terminal or a LCD screen from -100 to 100.·
In both displays if I do not clear the characters after every reading I will get invalid display readings once I hit 100 or my first negative 2 digit number.
For example:
X = 99············ First reading
X = 100·········· Second reading
X = 990·········· Third reading should be 99
X = 750·········· Fourth reading should be 75
X = -15·········· First negative reading
X = 155········· Positive reading of 15
X = -100········ Max negative
X = 9900········ Should be 99
Unless I clear the display first I will get garbage displaying.· This gives me a flicking effect that is not very desirable.· I can increase the pause but then I get a delay in my readings and it is just a slower flicker.
Is there a better way of clearing the undesirable characters without the flicking?
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
'...Initialize LCD
PAUSE 200
SEROUT 14, 84, [noparse][[/noparse]22, 12]
PAUSE 5
DO
·· PULSIN 6, 1, x
·· PULSIN 7, 1, y
·· x = (x MIN 1875 MAX 3125) - 1875 ** 10538 - 100
·· y = (y MIN 1875 MAX 3125) - 1875 ** 10538 - 100
·· DEBUG HOME, CLS, SDEC ? x, SDEC ? y
·· SEROUT 14, 84, [noparse][[/noparse]128, SDEC ? x, SDEC ? y]
·· PAUSE 100
·· SEROUT 14, 84, [noparse][[/noparse]12]
LOOP
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
For example:
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
'...Initialize LCD
PAUSE 200
PAUSE 5
DO
·· PULSIN 6, 1, x
·· PULSIN 7, 1, y
·· PAUSE 100
LOOP
WWW.HAPB.NET
WWW.HAPB.NET
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
'...Initialize LCD
PAUSE 200
PAUSE 5
DO
PULSIN 6, 1, x
PULSIN 7, 1, y
DEBUG HOME, CLREOL, SDEC ? x, CLREOL, SDEC ? y
PAUSE 5
SEROUT 14, 84, [noparse][[/noparse]SDEC ? x, SDEC ? y]
PAUSE 100
LOOP
WWW.HAPB.NET
