Stamp 1 progaming Help!
Hello,
I need basic stamp 1 code to ativate 6 led light strands from a PIR Sensor Module.
When the Sensor is activated,·the first·light strand should turn on for 5 sec and then turn off.
The next time the sensor is activated the second light should turn on for 5 sec then off.
After the 6 th light is turned on, the sequence should start over.
The unit leds are powered by a 12 volt battery
and the board is powered by the 9 volt
I have purchased
stamp 1 module
stamp 1 carrier board
PIR Sensor module
3 pin cable for sensor
darlington array- for ? voltage
adapter
serial cable
I need help
anyone?
I have purchased
stamp 1 module
PIR Sensor module
adapter
serial cable
I need help
anyone?
Also look at the documentation on the EFX-TEK Prop-1 which is a BS1 / Carrier board / Darlington Array combination
Tutorial www.parallax.com/tabid/535/Default.aspx/
App Notes www.parallax.com/tabid/440/Default.aspx
Prop-1 www.efx-tek.com/topics/prop-1.html
Looking this over,This LED message center unit is part of a much larger project that I am managing. I am on a tight deadline and I do not have the time to climb the learning curve for this element of the project. Is there anyone in Los angeles area that could work on this with me? All the parts are here, they just need to be put together.
