write command
Hi!
isn´t it possible to overwrite a value when using the WRITE command.
like
write 240,123
and after a while
write 240,198
but when i read the 240 using READ command i still get the 123.
why? and what do i do wrong?
like
write 240,123
and after a while
write 240,198
If this does not appear be happening, there must be something else going on with
your program. You'll have to post your whole program to get more specific help.
If you repeatedly write to the same location, eventually that location will wear out and
one or more bits will not be rewritable, but it takes a while for that to happen. The
minimum number of writes is in excess of 100,000, but, if you're rewriting the location
10 times a second, it would only take 3 hours to begin to have problems.
