Op Amp vs Instrumentation Amp — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2008-03-04 01:52 in General Discussion
Today's geek question.
What is the main difference between an Operational Amplifier and a Instrumentation Amplifier?
www.fd.com.my
www.mercedes.com.my
  • parskoparsko Posts: 501
    edited 2008-02-28 14:58
    William,
    I'm very happy you asked!!! I've been struggling with an op-amp design that I think is supposed to use and Instrumentational Amp instead. So, I've been reading up on both the past two weeks.
    In short, and Instr. amp has 3 op-amps internally (schematically). Instr. amps seem to buffer signals better, aka noise. They work very good with ADC's due to a low output impedance. Both the inputs are high impedance. I don't think they suffer from high frequency gain deterioration like a single op-amp design would.
    But, with all that said, I wish somewhere someone could explain when, where, and why one would use one versus doing the (seemingly) identical job with a single op-amp. This is where I have been stumped (since last weekend). I've wanted to ask the question, but...
    Would someone (who actually knows the theory!) chime in besides me??? I'm VERY interested in hearing about practical applications!
    -Parsko
    PS - My application uses a air temp guage from and auto, to be used in an auto, that changes in resistance from 1k-10k ohms (in the temp range I'm trying to work with). My op-amp design keeps failing, but I think it is due to TOO low of a value for my feedback loop (i'm using 325 and 3750 ohm resistors, when I think it should be 1000 times that much for both).
  • Beau SchwabeBeau Schwabe Posts: 6,573
    edited 2008-02-28 15:29
    This basically says it all...
    http://en.wikipedia.org/wiki/Instrumentation_amplifier
    Beau Schwabe
    IC Layout Engineer
    edited 2008-02-28 15:41
    Beau,
    I beg to differ (though, you are right in that it covers most of it). But, to a hobbiest, it misses the connections to the supply of the op-amps. In my reading, I seem to keep coming across every op-amp requiring a negative supply voltage (aka +12 AND -12 at the op-amp). Many times, we don't have a -12 supply available. Does this circuit specify that the -12 is actually hooked up to 0V, or -12V. I think this makes a difference. This has been confusing me when looking at op-amp schematics. I have a few links that I keep bookmarked (they are likely the same as found on wiki pages).
    www.pic101.com/op_amp.htm
    focus.ti.com/lit/an/slod006b/slod006b.pdf
    www.analog.com/UploadedFiles/Application_Notes/34661261AN369.pdf
    www.eng.yale.edu/ee-labs/morse/compo/sloa058.pdf
    www.phy-astr.gsu.edu/nelson/AN-31.pdf
    www.analog.com/UploadedFiles/Data_Sheets/897653854AD620_g.pdf
    As a hobbiest that does not quite understand the theory, nor have the experience with many applications (or having a mentor on sight to guide me), op-amps are tough to work with. I have determined that trial and error are the best method for me. But, that wiki page doesn't answer all my questions.
    -Parsko
    edited 2008-02-28 16:01
    parsko,
    The supply that you are referring to is negative with respect to "ground".· The ground connection can be imposed from a single voltage supply with the use of two resistors forming a voltage divider.· In your list of references, in the first reference (http://www.pic101.com/op_amp.htm) you·can see an example of how this is done by looking at Fig 26 and Fig 28.
    However, the relationship of V+ to GND to V- has nothing to do with the difference between an Operational Amplifier·verses an Instrumentation Amplifier.· That's another topic in and of itself.
    Beau Schwabe
    IC Layout Engineer
    edited 2008-02-28 16:21
    Beau,
    You just provided the "eureka" moment I needed. It's a "relative" ground reference!!!! Wow, that makes total sense now. We need a "eureka" Emoticon (one that would indicate that I just said out loud in a crowded office "ooooohhhhhhhhhhhhh")!!!!!
    Thanks!
    Now, back to the subject. Why would one use an inst. amp versus an op-amp? Yeah, higher accuracy, lower noise, etc... But, at what threshold does one pull the trigger and use an instr. amp? Is there a rule of thumb? When aren't we trying to get an accurate signal? What constitutes accuracy? I'm playing a bit of devil's advocate, but for those that know less than me (which is "relatively" hard), it's a hard question to answer.
    -Parsko
    edited 2008-02-28 17:22
    I suspect that the instrumentation amp is just a form of precision op amp. I hate to admit that I have only two reference books, but I keep going back to 'The Art of Electronics' for questions like these. I go to NEETs for the basics. Op Amps are definitely highly varied in quality and features. Some require V+ and V-, but many good ones do not.
    This book discusses more of the options than I really care to know. At the end of the day, the name instrumentaion amplifier as one package might just command a higher price. You can get 4 op amps in one package and create a better impedance relationship taylored to your exact needs. It is all about precision and low noise.
    Page 425 has a section 7.10 discussing 'standard three op-amp instrumentation amplifiers' [noparse][[/noparse]Fig7.32- Classic instrumentation amplifier]
    I even see a schematic [noparse][[/noparse]Fig. 7.33, page 26] all 4 units of a quad op amp being used to make an Instrumentation amplifier with output, guard, sense, and reference terminals. And of course, the one package requires only nominal power supply connections.
    The output is obvious. The guard goes to the coaxial inputs eternal shield. the reference goes to the load's grounded side, and the sense shares connection with the output on the load's higher voltage side.
    PLEASE CONSIDER the following:
    Do you want a quickly operational black box solution or the knowledge included therein?······
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
    edited 2008-02-28 17:42
    A true differential amplifier has the ability to cancel out any common mode signals that may get introduced on the input.
    A conventional Op-Amp can be configured to work in a differential mode, but because the output of the Op-Amp is often tied
    back to the inverting input or non-inverting input to increase/decrease the amount of desired gain, this tie-back configuration
    can introduce an imbalance that causes common mode signals to pass due to non-linearity’s·and get amplified when the idea
    is to have them suppressed.·
    An instrumentation amplifier is nothing more than a standard Op-Amp configured in a differential mode with isolation buffering
    to the inverting input and non-inverting input.· Because of the isolation buffering, you can·avoid the bias condition mentioned above.
    Nut shell bottom line...., is that if you have a differential signal, then you should use an Instrumentation Amplifier to achieve your
    absolute best signal to noise ratio on the output.· If you have a single ended signal, then a standard Op-Amp design is usually sufficient.
    Beau Schwabe
    IC Layout Engineer
    edited 2008-02-28 18:09
    Beau Schwabe (Parallax) said...
    ...., is that if you have a differential signal, then you should use an Instrumentation Amplifier to achieve your absolute best signal to noise ratio on the output. If you have a single ended signal, then a standard Op-Amp design is usually sufficient.
    The gem of information one cannot gleem by reading theory. Thank you very much Beau. The gem provided (me) the right search words, and subsequently, a much better understanding of electrical communication. This seems like something a CS101 professor would say on day one, and thus becomes common sense to professionals (but completely frustrating to the hobbiest!)
    -Parsko
  • RDL2004RDL2004 Posts: 2,554
    edited 2008-02-28 19:49
    Everyone that has any interest in op amps should download a copy of·the "Op Amps for Everyone" book·from Texas Instruments (at least read Chapter 1). Here is a link to the TI download:
    http://focus.ti.com/lit/an/slod006b/slod006b.pdf
    You can buy a printed version, but it's like $60 new. Might be worth it if you're really into electronics.
    - Rick
    edited 2008-02-29 09:00
    Thanks for the TI book reference.
    I've been sitting in Taiwan and wanting a good text that is just about Op Amps. I even purchaces an AsusEEE minilap top to store all those huge PDF when I go to Starbucks. Not only are they free, I don't have to carry around a 10 pound text. In fact, I have about 300 pounds of text in the Asus; including the Propeller Manual, the SX stuff, and BasisStamp Manual.
    Chapter 12 is entitled "Sensors to ADC" and looks extremely helpful.
    Post Edited (Kramer) : 2/29/2008 9:06:45 AM GMT
  • pwillardpwillard Posts: 321
    edited 2008-03-03 20:32
    I have some really old books that discuss Op Amps from the 1960's and treat them as an entity even though they are made up of discrete components.· It seems that they were always designed to handle a full voltage swing·+/- with respect to ground so they almost always require + and - voltage sources.· This is probably why chips like the ICL7660 (voltage inverter) were invented.
    There are some op amps, like the LM3900 that were specifically designed to operate from Single Sided supplies.
    I looked at the sample designs for the 3900 and oddly enough an instrumentation amp design was not provided.
    There's nothing like a new idea and a warm soldering iron.
  • ChrisPChrisP Posts: 136
    My only experience with Instrument amps was when I needed to amplify the signal from a wheatstone full bridge, the AD620·is a very simple and elegant solution when you have a two wire input that reverses polarity. Versus multiple op amps, trimming, resistors etc etc. The data sheet had some good comparisons and examples of op amps versus instrument amps.
