BOE_BOT RoboRealm with PAN/TILT
A while back a forum member posted some code (VB Script and .BS2) to get Roborealm working with the Boe-Bot ... the setup had 4 servos (2 wheels, one pan, one title) ... I am trying to get a copy or understand the setup (code) to control the pan/tilt servos ... I have the following code and·have been able to control my BB with it (just the wheel servos)·... I don't see any where in the code statements for the pan/tilt servos (VB or BS2)?
I know RR has added a new module for BB ... however their module is based on having an eb500 connection and I am using a XBEE connection (serial) so I am using the RR serial module for that portion ... If some one has a copy of the code or can explain (point me in the right direction) how to use the code I even have to get this working (pan/tilt) I would greatly appreciate it !!!!
Thanks in advanced!!!!
VBSCRIPT:
' initialize our start motor values to neutral
left_base = 750
right_base = 750
' get current image size
width = GetVariable("IMAGE_WIDTH")
center = width / 2
' get the size (width or height) of the current
' bounding box
size = GetVariable("COG_BOX_SIZE")
' if it is equal to "" then no object was detected
if size <> "" then
' get the horizontal center of gravity found by the COG
' module
cogX = GetVariable("COG_X")
' if it is less than 75 the blob is on the left side
' of the screen so move that way
if cogX < center-5 then
left_base = 750-(center-cogX)/2
right_base = 750
' otherwise move to the right if above 85 pixels (and no
' movement if 75 < cogX < 85 )
elseif cogX > center+5 then
left_base = 750
right_base = 750+(cogX-center)/2
end if
' if the ball is too close then we have to move backwards
if (size>90) then
left_motor = left_base+((40-size)*2)
right_motor = right_base-((40-size)*2)
' otherwise move forward
else
left_motor = left_base-((size-40)*2)
right_motor = right_base+((size-40)*2)
end if
' set the final motor values to be picked up by
' the SSC module
end if
if (size<20) then
left_motor=750
right_motor=750
end if
SetVariable "LEFT_MOTOR", CInt(left_motor)
SetVariable "RIGHT_MOTOR", CInt(right_motor)
PBASIC CODE
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
main:
SERIN 16,16780,[noparse][[/noparse]WAIT ("!"),DEC4 x,DEC4 y] ' Change SERIN 0,84,[noparse][[/noparse]WAIT ("!"),DEC4 x,DEC4 y] for eb500
PULSOUT· 14, x
PULSOUT· 15, y
PAUSE 5
GOTO main
VBSCRIPT:
left_base = 750
right_base = 750
center = width / 2
' bounding box
if size <> "" then
' module
right_base = 750
left_base = 750
end if
if (size>90) then
else
end if
' the SSC module
end if
if (size<20) then
left_motor=750
right_motor=750
end if
PBASIC CODE
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
main:
PULSOUT· 14, x
PULSOUT· 15, y
PAUSE 5
GOTO main
To make things easier I would start by adding the pan and getting that right before moving on to tilt. Also before including the pan value in the serial control and the Basic Stamp code I would first test the values from within the RR program. To get up and running with this you will need to add two more variables to the VB script, one variable to calculate the position of the "blob" and one variable for serial output. In keeping with the code that Tom wrote you might call the first variable pan_base and the second variable PAN_MOTOR, the second variable would be included at the end of the script taking it's value from pan_base
SetVariable "PAN_MOTOR", CInt(pan_base)
For test purposes you could get the value for pan_base from left_base and right_base
left_base = 750-(center-cogX)/2····· 'existing line
pan_base=left_base
right_base = 750+(cogX-center)/2·· 'existing line
pan_base=right_base
Using the Watch_Variables control (under Statements) you should be able to see the value of PAN_MOTOR change as you move your colored object left and right, the values may not be right to begin with but you should have an indication of how close or how far the calculation is.
Jeff T.
x VAR Word
y VAR Word
main:
SERIN 16,16780,[noparse][[/noparse]WAIT ("!"),DEC4 x,DEC4 y,DEC4 z] ' Change SERIN 0,84,[noparse][[/noparse]WAIT ("!"),DEC4 x,DEC4 y] for eb500
PULSOUT· 14, x
PULSOUT· 15, y
PAUSE 5
GOTO main
What would be the best way to add the VAR for PAN_MOTOR ...
x VAR Word
y VAR Word·
z VAR Word
main:
PULSOUT· 14, x
PULSOUT· 15, y
PULSOUT 13, z
PAUSE 5
GOTO main
Would this be correct?
! [noparse][[/noparse]LEFT_MOTOR] <lf> [noparse][[/noparse]RIGHT_MOTOR] <lf> [noparse][[/noparse]PAN_MOTOR] <lf>.
If your running with the test example I gave that is probably not going to work well. The link to the RR tilt routine Steve Joblin posted is your best bet for both axis, for pan just substitute the y with x.
That shouldn't be too hard now you have a handle on the VB script, if you need a little help with it post back.
Jeff T.
http://forums.parallax.com/showthread.php?p=646454
Sounds like you've about got it anyway!
Whit+
Jeff T.
STAMP:
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
z VAR Word
main:
PULSOUT· 15, x
PULSOUT· 14, y
PULSOUT· 12, z
PAUSE 5
GOTO main
VB:
left_base = 750
right_base = 750
pan_base = 750
width = GetVariable("IMAGE_WIDTH") - I am using 160x120 -
center = width / 2
' bounding box
if size <> "" then
' module
right_base = 750
pan_base = left_base
left_base = 750
pan_base = right_base
end if
if (size>90) then
else
end if
' the SSC module
end if
if (size<20) then
left_motor=750
right_motor=750
pan_motor=750
end if
The VB script is executed once every frame so we do not want to center the pan_base every frame we want to achieve a smooth left to right right to left movement. We also want to prevent the motor being driven beyond it's limits of between 500 and 1000. Eventually we will also have to account for the movement of the BOT, we want to try and achieve a position where the object is center screen and pan_base = 750. So if pan_base is at it's leftmost position (500) we want the BOT to turn left until pan_base is at 750. I have attached a modification to the VB script that initializes pan_position at 750 during the first 50 frames, after that a value is added or subtracted depending on the x location. You can try different values and see which works best, I started with a value of 2. At the end of the script there are two If...Then's to make sure the servo is not overdriven. There is a lot of room for improvement but this should give an idea if we are headed in the right direction.
Jeff T.
PULSOUT· 15, x
PULSOUT· 14, y
just to see if the pan smooths out.
Jeff T.
Jeff T.
Code if be the stamp code?
Here is what I have so far:
VB
count=GetVariable("IMAGE_COUNT")
if count <50 then
· pan_base=720
· left_base = 750
· right_base = 750
end if
center = width / 2
' bounding box
if size <> "" then
' module
· if cogX < center-5 then
··· left_base = 750-(center-cogX)
··· right_base = 750
· elseif cogX > center+5 then
··· left_base = 750
··· right_base = 750+(cogX-center)
· end if
· if (size>45) then
··· left_motor = left_base+((50-size)*5)
··· right_motor = right_base-((50-size)*5)
· else
··· left_motor = left_base-((size-50)*5)
··· right_motor = right_base+((size-50)*5)
· end if
if (size>90) then
left_motor=750
right_motor=750
end if
if pan_base<500 then
·· pan_base=500
end if
if pan_base>1000 then
·· pan_base=1000
end if
end if
STAMP:
' {$STAMP BS2}
' {$PBASIC 2.5}
x VAR Word
y VAR Word
z VAR Word
HIGH 15
FREQOUT 4, 500, 3000
LOW 15
main:
PULSOUT· 15, x
PULSOUT· 14, y
PULSOUT· 12, z
PAUSE 5
GOTO main
Left_base=750 and right_base=750 should not be included inside the If ...Then.
I'm attaching the last VB script that Tom posted and that he said was working well, use this in its unaltered form and let me know how the wheels perform.
Jeff T.
I also have a CMU-CAM and would like to use it to drive the PAN/TILT servos (12 Pan, 13 Tilt) ... this code works great that came with the cam ... I would think it would be pretty straight forward to add to more servos for the PAN/TILT to the code ... ANy thoughts on where to start with this [noparse]:)[/noparse]
'{$STAMP BS2}
'{$PBASIC 2.5}
' CMUcam1 BoeBot AppMod 1.2 Demo Program
' Copyright 2006, Seattle Robotics
' Basic Stamp 2
' CMUcam1 jumpered for 9600 Baud
' RA Nucci 07/13/2006
' Setup pins for buttons
INPUT 6
INPUT 8
HIGH 6
HIGH 8
RcvData VAR Byte(10) ' Array
SaveColorData VAR Byte(6) ' Array
Result VAR Word
N VAR Byte ' General purpose counter variable
LostTrack VAR Nib
Switch VAR Nib
Debounce VAR Nib
Function VAR Nib
Main:
' Pause for CMUcam1 startup
· FOR N = 2 TO 5 ' Flash all LED's during pause
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255]
··· PAUSE 400
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0]
··· PAUSE 400
· NEXT
· FREQOUT 10, 400, 2500 ' Beep to indicate ready
ProgTop:
· ' Select function from push buttons
· GOSUB GetButton
· Debounce=Switch
· GOSUB GetButton
· ' Get button press twice and compare if not the same repeat
· IF Debounce <> Switch THEN ProgTop
· IF Switch = 2 THEN ' If Go/Stop button pushed then beep
··· FREQOUT 10, 400, 2500 ' beep
· ENDIF
BRANCH Switch, [noparse][[/noparse]ProgTop,Buttonselect,Execute]
Buttonselect:
· Function = Function + 1
· IF Function > 9 THEN
··· Function = 1
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]1]
· ENDIF
· PAUSE 300
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD(Function-1)]
GOTO ProgTop
Execute:
· BRANCH Function, [noparse][[/noparse]ProgTop,Calibrate,SaveColor,TrackColor,Avoid,Adapt,FollowLine,Point,Color]
GOTO ProgTop
GetButton:
· Switch=0
· IF IN6 = 0 THEN
··· Switch = 1 ' Select button pressed
··· RETURN
· ENDIF
· IF IN8 = 0 THEN
··· Switch = 2 ' GO/Stop button pressed
··· RETURN
· ENDIF
· IF IN8 = 0 AND IN6 = 0 THEN
··· Switch = 3 ' Both buttons pressed at the same time
· ENDIF
RETURN
' Track the color previously saved in EEPROM
TrackColor:
· GOSUB ConfigureCMUcam
· ' Read EEPROM into SaveColorData array
· READ 0, SaveColorData(0)
· READ 1, SaveColorData(1)
· READ 2, SaveColorData(2)
· READ 3, SaveColorData(3)
· READ 4, SaveColorData(4)
· READ 5, SaveColorData(5)
· ' Set Track Color values from EEPROM
· SEROUT 7,84,[noparse][[/noparse]"TC"]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(0)]
· SEROUT 7,84,[noparse][[/noparse]" "]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(1)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(2)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(3)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(4)]
· SEROUT 7,84,[noparse][[/noparse]DEC SaveColorData(5),CR]
· PAUSE 200
TopTrack:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
· GOSUB GetButton· ' Check for stop button press
· IF Switch = 2 THEN' Switch 2 is stop button
· ' Two beeps for Stop
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (Function-1)]
··· PAUSE 200
··· PAUSE 200
··· ' Reset the green tracking LED
··· SEROUT 7, 84, [noparse][[/noparse]"L1 0",CR] ' Green LED off
··· PAUSE 100
··· SEROUT 7, 84, [noparse][[/noparse]"L1 2",CR] ' Green LED auto mode
··· PAUSE 100
··· GOTO ProgTop
· ENDIF
· ' Send command - Track color (with no arguments) -
· ' will track last color grabbed by TW command
· SEROUT 7, 84, [noparse][[/noparse]"TC",CR]
· SERIN 9, 84, [noparse][[/noparse]STR RcvData\10]
· PAUSE 100
· ' 45 is aprox H center, 70 is aprox V center
' Track and follow logic
IF Function = 3 THEN
· IF RCVData(2) > 65 AND RcvData(9) > 25 THEN RotateLeft
· IF RCVData(2) < 25 AND RcvData(9) > 25 THEN RotateRight
· IF RCVData(7) > 120 AND RcvData(9) > 25 THEN Bwd
· IF RCVData(7) < 60· AND RcvData(9) > 25 THEN Fwd
ENDIF
' Move and avoid logic
IF Function = 4 THEN
· IF RCVData(3) > 50 AND RcvData(9) > 20 THEN Fwd
· IF RCVData(3) < 50 THEN BackUp
· IF RcvData(9) <= 20 THEN BackUp
ENDIF
' Adaptive tracking logic
IF Function = 5 THEN
· IF RCVData(7) < 60 AND RcvData(9) > 25 THEN Fwd
· IF LostTrack > 6 THEN TW
· LostTrack = LostTrack + 1
· IF RcvData(9) > 25 THEN LostTrack = 0
ENDIF
' Line Following logic
IF Function = 6 THEN
· IF RCVData(2) > 50 AND RcvData(9) > 5 THEN TurnLeft ' 45
· IF RCVData(2) < 40 AND RcvData(9) > 5 THEN TurnRight ' 45
· IF RCVData(2) >= 40 AND RCVData(2) =< 50 AND RcvData(9) > 5 THEN Fwd
ENDIF
' Finger point logic
IF Function = 7 THEN
· IF RCVData(2) > 60 AND RcvData(9) > 25 THEN RotateRight ' Centroid X
· IF RCVData(2) < 30 AND RcvData(9) > 25 THEN RotateLeft ' Centroid X
· IF RCVData(3) > 30 AND RcvData(9) > 15 THEN Bwd ' Centroid Y
ENDIF
' Color logic
IF Function = 8 THEN
· SEROUT 7, 84, [noparse][[/noparse]"TC 30 240 16 30 16 30",CR] ' Red
· IF RcvData(9) > 20 THEN
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]195] ' All Red LED's on
··· PAUSE 500
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' All LED's off
· ENDIF
· SEROUT 7, 84, [noparse][[/noparse]"TC 16 40 30 240 90 170",CR] ' Green
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]24] ' All Green LED's on
··· PAUSE 500
· ENDIF
· SEROUT 7, 84, [noparse][[/noparse]"TC 200 240 200 240 16 50",CR] ' Yellow
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]36] ' All Yellow LED's on
··· PAUSE 500
· ENDIF
ENDIF
· ' Flash LED's to show bottom of tracking loop
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]129] ' 100000001
GOTO TopTrack
' Calibrate CMUcam1 for lighting conditions
Calibrate:
· ' Reset CMUcam1
· SEROUT 7, 84, [noparse][[/noparse]"RS",CR]
· PAUSE 200
· ' Turn on auto adjust
· SEROUT 7, 84, [noparse][[/noparse]"CR 18 44",CR]
· PAUSE 100
· ' Delay loop for CMUcam1 to auto adjust to lighting conditions
· FOR N = 2 TO 255
··· PAUSE 100
··· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]DCD (N)]
··· GOSUB GetButton ' Check for stop button pressed
··· IF Switch = 2 THEN EXIT ' Switch 2 is stop button
· NEXT
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]0] ' 000000000
· ' Turn off auto adjust
· SEROUT 7, 84, [noparse][[/noparse]"CR 18 44 19 32",CR]
· PAUSE 100
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]1] ' 100000000
· PAUSE 300
GOTO ProgTop
SaveColor:
' sample and save color
· SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]
· PAUSE 100
· ' Set a small window in center
· SEROUT 7,84,[noparse][[/noparse]"SW 30 54 50 90",CR]
· PAUSE 100
· ' Set raw mode 3
· SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]
· PAUSE 100
· 'set minimun and maximun values
· SaveColorData(0)=16
· SaveColorData(1)=240
· SaveColorData(2)=16
· SaveColorData(3)=240
· SaveColorData(4)=16
· SaveColorData(5)=240
· ' Get Mean
· SEROUT 7,84,[noparse][[/noparse]"GM",CR]
· SERIN 9,84, [noparse][[/noparse]STR rcvdata\8]
· PAUSE 200
· IF rcvdata(2)<=46 THEN gm1
··· SaveColorData(0)=(rcvdata(2)-30)
· gm1:
· IF rcvdata(3)<=46 THEN gm2
··· SaveColorData(2)=(rcvdata(3)-30)
· gm2:
· IF rcvdata(4)<=46 THEN gm3
··· saveColorData(4)=(rcvdata(4)-30)
· gm3:
· IF rcvdata(2)>210 THEN gm4
··· saveColorData(1)=(rcvdata(2)+30)
· gm4:
· IF rcvdata(3)>240 THEN gm5
··· saveColorData(3)=(rcvdata(3)+30)
· gm5:
· IF rcvdata(4)>240 THEN gm6
··· saveColorData(5)=(rcvdata(4)+30)
· gm6:
· ' Set raw mode to 0
· SEROUT 7,84,[noparse][[/noparse]"RM 0",CR]
· PAUSE 100
· ' Return window to full size
· SEROUT 7,84,[noparse][[/noparse]"SW",CR]
· ' Write color tracking range values to end of EEPROM
· WRITE 0,saveColorData(0)
· WRITE 1,saveColorData(1)
· WRITE 2,saveColorData(2)
· WRITE 3,saveColorData(3)
· WRITE 4,saveColorData(4)
· WRITE 5,saveColorData(5)
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]2]
· ' Two beeps
· PAUSE 400
· PAUSE 400
GOTO ProgTop
Avoid:
· SEROUT 7,84,[noparse][[/noparse]"TW",CR]
· PAUSE 1000 ' Wait 1 second for TW
GOTO TopTrack
Adapt:
TW:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]255] ' All LED's on
· FREQOUT 10, 150, 2500 ' Beep
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"TW",CR] ' Send Track Window command
· PAUSE 1000 ' Wait 1 second for TW to complete
· LostTrack = 0 ' Reset LostTrack counter
GOTO TopTrack
FollowLine:
· SEROUT 7,84,[noparse][[/noparse]"TC 16 50 16 50 16 50",CR]' Black line color
· PAUSE 100
GOTO Toptrack
Point:
· SEROUT 7,84,[noparse][[/noparse]"TC 200 240 180 240 50 100",CR] ' Skin color
· PAUSE 100
GOTO Toptrack
Color:
GOTO Toptrack
ConfigureCMUcam:
· SEROUT 7,84,[noparse][[/noparse]"PM 1",CR]' Poll Mode
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"RM 3",CR]' Raw Mode
· PAUSE 100
· SEROUT 7,84,[noparse][[/noparse]"CR 32 8",CR]' White Balance smart mode
· PAUSE 100
RETURN
BackUp:
· ' backup
· FOR n = 1 TO 15
··· PULSOUT 14,1000 ' **
··· PULSOUT 15,500 ' **
··· PAUSE 15
· NEXT
· PAUSE 200
· ' rotate about 90 degrees
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]32]
· FOR n = 1 TO 100
··· PULSOUT 15,1000 ' **
· NEXT
GOTO TopTrack
RotateLeft:
· SHIFTOUT 5,11,MSBFIRST,[noparse][[/noparse]4]
· FOR n = 1 TO 10
··· PULSOUT 14,500 ' **
· NEXT
GOTO TopTrack
RotateRight:
· FOR n = 1 TO 10
· NEXT
GOTO TopTrack
TurnLeft:
· FOR n = 1 TO 40
··· PULSOUT 15,750 ' **
· NEXT
GOTO TopTrack
TurnRight:
· FOR n = 1 TO 40
··· PULSOUT 14,750 ' **
· NEXT
GOTO TopTrack
Bwd:
· FOR n = 1 TO 10
··· PAUSE 15
· NEXT
GOTO TopTrack
Fwd:
· FOR n = 1 TO 10
··· PAUSE 15
· NEXT
GOTO TopTrack
