Read from sequential file
as I'm new to the propellor chip and microcontrollers in general I'd like to know if it is possible by using the VDrive (Vinculum chip) to read a number of characters (8) from a large txt file (> 16Mb) located on a Thumb drive, beginning at a particular location, then consecutively read the next set of 8 characters and so on. I ask because I'm considering purchasing the VDrive for a project, but I'm not sure if this can be 'relatively' easily done. Are there any other better (easier) solutions. I could use CF or SD cards if tis were to make the process easier.
Any help would be greatly appreciated.
There is a seek command that takes an absolute address within a file and positions the file to that location for subsequent operations (like reads). When you specify a read, you indicate how many characters are to be read.
just looked at the manual. Am I correct in saying that when I use seek it goes to that location. Then to read 8 characters from that location I use RDF 8 and is it also true that if I use WRF 8 it will overwrite any existing data with the new data?
