Project almost finished, but Protoboard won't use xtal anymore
I just finished putting my protoboard (w/ acessory kit + video and audio out) into a project box. I tested it out with Femtobasic on the TV, and everything seemed fine. I turned the board off and on again with a switch I connected across the onboard one. This time the TV stayed blank. I kept toggling and a few tries later Femtobasic started again. I checked the board with my multimeter and the regulators seemed fine, but the board still wouldn't work. I added an LED and tried testing, and the board doesn't seem to want to run using the crystal (internal clock is fine, and I can connect to the prop). I switched out the crytal to my propstick, and it seemed to work. I also checked the connector for the crystal, which·seems to be corrected properly.·Did I just ruin my protoboard?
Run a testprogram, which turns and LED on some pin on and off by CLKFREQ.
Run this program
- in RCFAST mode
- without any PLL setting
- with PLL1X
- with PLL8X
When does it work, when not?
Edit: I also noticed a voltage drop on my multimeter when the propeller was in the box, I probably a short somewhere, but I took the prop out of the box when I saw the drop and it went away.
Post Edited (Jake11611) : 2/27/2008 2:38:10 AM GMT
I suggest you call Tech Support tomorrow. They may have some suggestions.
