out of variable space
Hello All,
Is it possible to define a variable as a size between byte and word. Byte 0 to 255 is too small to give my array of 7 photo-resistors enough range to read the fluctuating range of the photos. If I define them as word variables I run out of variable space. The program I am working on takes an initial light reading from the space. From that it subtracts all of the numbers from a base number and uses the difference to start all of the new readings at the same point. Here is an example of a debugging version....
' {$STAMP BS2}
' {$PBASIC 2.5}
photo0 VAR WORD
photo1 VAR WORD
photo2 VAR WORD
photo3 VAR WORD
photo4 VAR WORD
photo5 VAR WORD
photo6 VAR WORD
dif0 VAR WORD
dif1 VAR WORD
dif2 VAR WORD
dif3 VAR WORD
dif4 VAR WORD
dif5 VAR WORD
dif6 VAR WORD
base CON 100
start:
HIGH 0
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
dif0 = ABS (photo0 - base)
dif1 = ABS (photo1 - base)
dif2 = ABS (photo2 - base)
dif3 = ABS (photo3 - base)
dif4 = ABS (photo4 - base)
dif5 = ABS (photo5 - base)
dif6 = ABS (photo6 - base)
main:
HIGH 0
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
DEBUG HOME, DEC5 ? ABS (photo0-dif0)
DEBUG DEC5 ? ABS (photo1-dif1)
DEBUG DEC5 ? ABS (photo2-dif2)
DEBUG DEC5 ? ABS (photo3-dif3)
DEBUG DEC5 ? ABS (photo4-dif4)
DEBUG DEC5 ? ABS (photo5-dif5)
DEBUG DEC5 ? ABS (photo6-dif6)
GOTO main
I will use the (photo#-dif#) readings to articulate a series of servo motors. I realize that photo-resistors are not the most accurate way to gather light information for this piece accuracy is not important. I embrace the fact that they fluctuate.... I just need the readings to start off all at the same place... if that makes any since. Is there way to divide a word variable in half? 0 to 32767 would give me more than enough range to do what I want. Any assistance would be great.
Check out my latest piece currently on exhibit in brainwave at exit art http://www.dwbowen.com/swarm.html
cheers!
david bowen
' {$STAMP BS2}
' {$PBASIC 2.5}
photo0 VAR WORD
photo1 VAR WORD
photo2 VAR WORD
photo3 VAR WORD
photo4 VAR WORD
photo5 VAR WORD
photo6 VAR WORD
dif0 VAR WORD
dif1 VAR WORD
dif2 VAR WORD
dif3 VAR WORD
dif4 VAR WORD
dif5 VAR WORD
dif6 VAR WORD
base CON 100
start:
HIGH 0
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
main:
HIGH 0
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
GOTO main
cheers!
david bowen
Something like
photo var word
diff var word
channel var nibble
base con 100
main:
for channel = 0 to 6
high channel
pause 3
RCTIME 0,1,photo
diff = abs(photo-base)
debug home,dec5 ? ABS(photo - diff)
next
goto main
I guess it depends on how you plan to manipulate the servos and how time critical it is. If the servos can be commanded at different times then just calculate the value you need in each loop and send that to the relevent servo. If all servos need their commands as close together as possible then you might be able to use a single variable to contain a cumulative value in.
Say you had those sensors arranged in a circle and you wanted to head to the brightest point. You would just store the brightness value in one variable and then a direction value for that sensor in another. Each loop you check the new brightness against the stored value and it the new one is brighter you store the new brightness and the new direction and keep cycling until all sensors had been checked. When the loop finishes you can command the servos to do what you want based on the stored direction value.
Of course, thats just one example off the top of my head. If we knew more about what you wanted to do it'd be easier to make suggestions.
PatM and Chris,
The readings will be compiled and sent to a servo driver ideally causing the servos to respond in real time simultaneously to whatever the readings are. I do not think that storing the values would work as the device will be continuously updating its position based on the light readings it gathers. When the piece is turned on I would like the servos to gather a light reading when centered from the space and then continually change the composition based on the fluctuation of the light through out the day. The only way I can see to do this in realtime is to store all of the variables so the controller can access them and adapt to the changing readings... if this makes any sense at all???
Mike,
I think I understand what you mean by storing partial variables by splitting them and adding them back together... but I am a little shaky on how I would adapt it to my program.
photos var word
photo1 var photos.lowbyte
photo2 var photos.hightbyte
main:
high 0
pause 1
rctime 0,1, (photo1+photo2)
debug home, dec4 ? (photo1+photo2)
goto main
Of course this doesn't work or even solve my problem with memory as I am still using a word variable to define one photo.... but am I at least on the right track?
cheeri0!
Here is the program I would like to run.
' {$STAMP BS2}
' {$PBASIC 2.5}
photo0 VAR WORD
photo1 VAR WORD
photo2 VAR WORD
photo3 VAR WORD
photo4 VAR WORD
photo5 VAR WORD
photo6 VAR WORD
dif0 VAR WORD
dif1 VAR WORD
dif2 VAR WORD
dif3 VAR WORD
dif4 VAR WORD
dif5 VAR WORD
dif6 VAR WORD 'out o variable space
pw_x VAR WORD
pw_y VAR WORD
baud_driver CON 396
z CON 1
base CON 20
start:
HIGH 13 'start water pump
HIGH 0 'collect an initial light reading from the space
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
pw_x = 750 'center all x servos
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 0, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 2, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 4, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 6, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 8, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 10, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 12, 15, pw_x.LOWbyte, pw_x.highbyte, CR]
pw_y = 750 'center all y servos
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 1, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 3, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 5, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 7, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 9, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 11, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
SEROUT 15, baud_driver+$8000,[noparse][[/noparse]"!sc", 13, 15, pw_y.LOWbyte, pw_y.highbyte, CR]
dif0 = ABS (photo0 - base) 'determine difference between initial light reading AND base # in order to unify the readings
IF IN14 = 0 THEN main 'check water level
GOTO start
main:
LOW 13 'stop pump
HIGH 0 'collect new light reading form space updated every time the program loops
HIGH 1
HIGH 2
HIGH 3
HIGH 4
HIGH 5
HIGH 6
PAUSE 3
RCTIME 0,1,photo0
RCTIME 1,1,photo1
RCTIME 2,1,photo2
RCTIME 3,1,photo3
RCTIME 4,1,photo4
RCTIME 5,1,photo5
RCTIME 6,1,photo6
pw_x = ABS (((((((photo1-dif1)+(photo6-dif6))/2)+(photo0-dif0))/2)/z)+750-((((photo3-dif3)+(photo4-dif4))/2)/z)) 'use updated (realtime) readings-unified readings (initial-base) to articulate x servos
pw_y = ABS ((((photo6-dif6)+(photo5-dif5))/5)/z)+750-((((photo1-dif1)+(photo2-dif2))/5)/z) 'use updated (realtime) readings-unified readings (initial-base) to articulate x servos
goto main
I have seven devices arranged in a circle. Each has an x servo and a y servo connected to a vertical piece with a photoresistor on the end. As you can see the servos are controlled by a servo driver. Ideally I would like the collective of seven to move toward the light in a particular space in realtime. The movement of the devices will fluctuate when people walk around the piece casting shadows on particular photoresistos. They will be repelled by shadows and attracted to light. I have the system working by defining the dif# variables as byte, but the photoresistors can fluctuate from 50 to 500. From my perspective the dif# readings need to be saved throughout the program but the byte variables cannot handle this range so the system doesn't always work. I like the fact that photoresistors fluctuate so drastically. I would like to find a way for the basic stamp to handle it. One option I am considering is wiring two stamps together and splitting the photos between them. Any ideas on solving this through the programing.
cheers!
david bowen
The BS2 IS quite limited in variable space. So you need to define some "Tempxxx" variables, use them in subroutines, and only 'save' the data you really need.
You DO have 13 'Word' variables, which gives you 7 to 'store' with, leaving 6 to process with. But then you need to be very careful about those 6.
