FullDuplexSerial Question ...
Hello all,
I have a transmitter attached to my Prop with Pin 0
being the outpin pin for my transmitter. I am using the command :
data.start(1,0,0,9600) the Third parameter being the
invert rx command. At the moment I am
Using a 1K Pull-up resistor on my Tx line and my line is being held high at 2.72 volts instead of 3.3v
When I try and change that parameter to "2" open drain / Source Tx
with a 1k pull-up my line idles high, drops low for the start bit but after the data it stays low. I am confused about the third parameter of FullDuplexSerial
Can someone give me the correct command for the Line to Idle high, pull low for the start bit transistion and then go back high after the data is sent ?
JMLStamp2p
JMLStamp2p
Open drain/source on transmit means that the idle state of the line, the stop bits, and any data bits that are the same as the stop bit are high impedance (open drain/source) and their voltage is set by a pullup resistor. The other state (start bit and any data bits that are the same) is actively driven. In your case, you should use a mode value of %0100 which is the same as $4 or 4. You put "2" by mistake.
'' mode bit 0 = invert rx
'' mode bit 1 = invert tx
'' mode bit 2 = open-drain/source tx
'' mode bit 3 = ignore tx echo on rx
JMLStamp2p
I'd like to thank you for your continued help. I now have my Tranciever recieving the data that I am sending and showing up correctly on my LCD. I thought about what you said concerning the flow of my program and would like your opinion.
My objectives:
1) Recieve method running in a seperate Cog.
2) Keypad method running in a seperate Cog.
3) A method that monitors inputs from "3" limit switch's.
4) A Transmit method that transmits "Countdown" Global varibles out the port.
5) To have one program that can run in both Props, Transmitter & Reciever.
6) 2 - seperte serial ports, one for the LCD setup at 19200 baud and one for the Tranciever
setup at 9600 baud.
Basic setup for Flow Below, please let me know if I am approaching it right.
VAR:
Long TValue_1, TValue_2, TValue_3, Stack_1 [noparse][[/noparse] 20], Stack_2 [noparse][[/noparse] 20]
OBJ:
data_Tran: "Extended_FDSerial"
data_LCD: "Extended_FDSerial"
delay: "Clock"
num: Numbers
PUB Main | Value
cognew(Recieve(Num_of_chars, @ datain_1), @Stack_1)
cognew(Keypad(Num_of_chars_K, @datain_2), @Stack_2)
Clear_LCD
Check_Limits
Transmit_timer_values
I'm trying to learn the approach of writing a program by logical steps that accomplish a certain task. I realize that I may not need a seperate cog for these task but would like to make the project as efficient as possible.
JMLStamp2p
