H-Bridge delivering half voltage, what's up?
I have created an H-Bridge using four darlington (TIP120) transistors to power a motor. The bases of the four pins are connected to a BS2. The transistors, when activated in pairs, supply 12V to the motor, either in a forward or reverse direction. The problem is that they only seem to be supplying right around 5 Volts. I have checked the collector emitter of each transistor and it indeed registers 12V.
Why would the motor only be supplied with around 5 Volts?
Blake
Blake
You COULD be measuring the voltage incorrectly -- an H-Bridge needs to be measured across the motor, not from one lead to ground. Though that shouldn't matter.
You COULD be controlling the H-Bridge incorrectly.
You COULD be using too small (too little current available) in your 12-volt supply, and the motor current is pulling down the voltage.
