Im Stumped
Hey All,
I have written code for an A/D that has an averaging function in another cog. These two cogs are synced so that they start at exactly the same time. The first cog does the ADC and the second cog adds up every 100 values for averaging.
I put in a "spike" in the code for the second cog so I could see it on an oscilloscope.
When I put the prop on the scope it indicates that the second cog is not starting for an extended amount of time. This "spike" usually appears after 2-4 minutes.
Im sure my code for syncing the cogs is correct as I have used it previously without any trouble.
Can anybody spot anything obviously wrong with my code? Ive been trying to find the cause of this for a couple days now and am out of ideas.
*Nevermind the cogstop statements at the beginning that was one last attempt to make it work
Thanks for any help,
Tom
Post Edited (tom90) : 2/26/2008 7:47:22 PM GMT
mov outa, tester 'Spike to be seen on scope
andn outa, tester
Tom
Also, have a look how COGSTOP should be used...
Why don't you use 80 MHz?
